Home > Maintenance & Modifications > Bulkhead mounted spare wheel
Mud Dog
Hi,
I've got a 2002 90 and want to mount my spare wheel (285 75 r16) against the bulkhead. I've seen the old series bracket but don't know if it will fit the bill. Anyone done this or have any thoughts?
The only other thing I fount was this:
http://www.allbrit.de/UNI.cfm?PAGE=770895&...SPRACHE=EN
Any advice would be welcome
Thanks We're not stuck...just enjoying the scenery!
Post #339765 22nd Jun 2014 8:35am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I would think the spare wheel mounting bracket from a double cab will do the job nicely
Post #339883 22nd Jun 2014 7:54pm
paulnb57
I have the bracketry you require in the surpus to requirements area (shed!) if you need the parts, the bulkhead mount is used, but the part with the wheel studs is new and as fitted to the Tomb Raider Double Cab, for sale if you wish....,
pm me if you want it although mail might be quite dear.........
£30 plus post. (bargain!)
I can post a photo later.......
Paul
Edit...just looked at you lonk and the parts I have are 1 and 17.....
Post #340021 23rd Jun 2014 10:11am
K9F
I also have the original wheel carrier from the rear door of my 08XS. I am heading to Kent tomorrow, you're welcome to it free-gratis if it's any use.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #340025 23rd Jun 2014 10:15am
GUM97
Mine used to be mounted to the bulkhead, but for the life of me I can't remember how it attached Embarassed An engine to TDi for!
Post #340031 23rd Jun 2014 10:22am
jimbob7
My Defender came with what looks like an older version of the rear door mount bolted to the bulkhead.
One of these.
 Pov.spec,ftw. 2006, 110,TD5.
Post #340036 23rd Jun 2014 10:44am
paulnb57
The problem when using the mount from a rear door is that a flat tyre would no longer touch the floor and put a lot of strain on the centre bulkhead......
Paul
Post #340387 24th Jun 2014 7:11am
jimbob7
More strength in the bulkhead than the door,anyways I wouldn't bother mounting a flat tyre, just throw it on the floor. Pov.spec,ftw. 2006, 110,TD5.
Post #340428 24th Jun 2014 10:39am
paulnb57
Might as well throw the good one on the floor then!??
Paul
Post #340434 24th Jun 2014 11:11am
