![]() | Home > My Defender > Bit more progress on the soft top conversion. |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
no probs. im taking pics as a i go along. ive created a build thread already so you can see where I was up to about 12 months ago! i need to bring the story up to date with my current soft tops mods !
one to whet your appetite. these are my new series door bottoms and rocky mountain ali door tops. Lovely bit of kit.
Cage was easy. Door surrounds a complete nightmare! Do you vertical door surround pieces match to the holes on the cage? The bottom one is way out and it looks like the bottom slanted rain run off needs bending! One for tomorrow but any tips welcome!
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
Mikeh501
Hi yes I needed to bend the bottom of the door shut mine never lined up even after bending they were still 8 mm out of line with the track the rubber seal pushes onto, doesn't seem to matter as after a week of the door being shut it works a treat now with no further adjustments. Have just finished fitted the hood with the tenex fittings, you have saved yourself some grief not using them! |
Did you need to drill a new hole to fit the lower bolt from the vertical door surround so it matches up to the cage hoop?
No they should line up with plenty to spare as there slotted.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Took the 90 out for its first proper drive since I took it all apart and put it back together again.
Stopped on way for a few arty photos!! Q ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1731 ![]() ![]() |
Very nice definitely looks like it was worth the time and effort. Look forward to seeing it, well done so far
Next week new shocks springs and bushes, and on the look out for some new seats also.
Been hard work but enjoyable and rewarding, got some ![]() ![]() |
Really nice ! Mine is also now complete! Took some serious hours thus weekend
Getting excited after 4 weeks in the body shop my complete strip down and respray is finished, I have replaced every nut and bolt replaced all the panels except the bonnet, fitted new series doors and Rocky Mountain door tops, new door hinges and bonnet hinges, windscreen hinges, fitted new grills and led headlights. It's almost a brand new 15 year old Landrover hopefully picking it up Saturday if time and will post a few pictures of the finished result, been a labour of love but to anyone thinking of doing one it's worth it.
