![]() | Home > For Sale & Wanted > [Wanted] ABS pump. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Get it tested....
http://www.ecutesting.com/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I bought new (Wabco) from Brookwells (sourced from BR*TPART) for £1100+VAT,LR want £2k,mines a TD5.You really need the fault code/s (LR codes not the generic faultcodes, Snap on, etc.).There is only so much you can fix on them,but if it can be fixed ecu testin is your best bet.
P.s fitting it is as much fun as paying for it |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
I got a second-hand one for £150 and after a pig of a job fitting it, its been working well for the last 2 years.
The fault codes on mine were "Sticking Shuttle Valves", but sent it to ECUtesting and they confirmed that the modulator pump motor was seized and it was fubar'd..! If I recall, the testing was free, only paid for postage. cheers simon |
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808
Before you send it off, check for simple problems in the wiring. My problem was a loose/corroded terminal on the relay under the drivers seat. I only found this out after spending close to £100 sending it to ECU testing and them sending it back saying there was no fault. 2002 110 td5
