Home > Maintenance & Modifications > Quick advice needed
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Quick advice needed
Just about to fit td5 lower door rubber deals and not sure which way around they go, both ways seem to fit?
This way A
Or this way B
Post #336590 8th Jun 2014 11:22am
Leenorthants
I think it's b
Post #336606 8th Jun 2014 12:57pm
shaggydog
B, Won't work the other way around.
Post #336614 8th Jun 2014 1:46pm
excossack
What year TD5 is it ?
I have a 1999 td5 and my front door seals are more like this > http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3cdac9dc94
A bit like an L shape. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #336615 8th Jun 2014 2:02pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Re: Quick advice needed
Leenorthants wrote:
I think it's b
I too !
........or use LR029309 - Weatherstrip Door Lower
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #336620 8th Jun 2014 2:27pm
excossack
Are they good for a TD5 ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #336623 8th Jun 2014 2:40pm
B. Thumbs Up
Post #336625 8th Jun 2014 3:26pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Definitely B Thumbs Up
Post #336662 8th Jun 2014 6:37pm
Fullfat
Thanks all it was b, all fitted and quite an easy job for a change, more then I can say for fitting the radio today!!
Post #336664 8th Jun 2014 6:44pm
excossack
How did you attach it - via rivets? 1999 Defender TD5 110
Regards
John M0VAZ
Post #336665 8th Jun 2014 6:55pm
Fullfat
Yes just riveted it on, easy job, makes a change every job I do usually turns into another and another!!!
Post #336683 8th Jun 2014 8:04pm
excossack
You got a part number ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #336686 8th Jun 2014 8:15pm
Fullfat
ALR6250 same for both sides and used eight rivets each side,added a few more as the end holes overhand the door a bit.
Drilled a 4.5mm hole for the rivets, gets some better rivets then the britparts ones I got as they are not the best.
Post #336687 8th Jun 2014 8:18pm
Fullfat
Post #336688 8th Jun 2014 8:22pm
excossack
Cheers ears! 1999 Defender TD5 110
Regards
John M0VAZ
Post #336695 8th Jun 2014 8:52pm
