![]() | Home > Maintenance & Modifications > Quick advice needed |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
I think it's b
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
B, Won't work the other way around.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
What year TD5 is it ?
I have a 1999 td5 and my front door seals are more like this > http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3cdac9dc94 A bit like an L shape. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
I too ! ........or use LR029309 - Weatherstrip Door Lower ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Are they good for a TD5 ? 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
B.
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Definitely B
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
Thanks all it was b, all fitted and quite an easy job for a change, more then I can say for fitting the radio today!!
How did you attach it - via rivets? 1999 Defender TD5 110
Yes just riveted it on, easy job, makes a change every job I do usually turns into another and another!!!
You got a part number ? 1999 Defender TD5 110
ALR6250 same for both sides and used eight rivets each side,added a few more as the end holes overhand the door a bit.
Drilled a 4.5mm hole for the rivets, gets some better rivets then the britparts ones I got as they are not the best. |
Cheers ears! 1999 Defender TD5 110
