![]() | Home > 130 > It's started, Longshanks will no longer be a Pick up |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
Well my girlfriend has just had to get the wet and dry vac out as I've been drooling over your 130's. They are all so well build and modded.
Chris. |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
good thing you said that before I cut mine off to find out ![]() |
Aquarius0 Member Since: 21 Apr 2014 Location: Rumia Posts: 14 ![]() ![]() |
When are you planning to show the end effect of the transformation?
Waiting for more photos ![]() |
Been very busy at work so not had chance to work on Longshanks, however yesterday I managed to move the 2nd row seats back by 130mm giving a fair bit more leg room. (pics to follow) although you can see the reduced seat box in the second pic.
I also started on the body to tub mating plate. This in an 8mm thick hi grade ally plate that will be cut into a big U shape, here you can see it in place waiting to be marked up prior to being cut into shape. ![]() Click image to enlarge ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
Looking good Andrew, I can't wait for the next installment!
Is this how you did the conversion on J-Lo, or are there improvements based on what you learned last time? |
Yea same thing sort of thing, but this time I'm being a bit more er ........ lets make use of the wasted space.
I cut out the 'adapter plate' today and welded a support angle to it
![]() ![]() Click image to enlarge ![]() Click image to enlarge The tub is off having the front posts welded in 'up right'. As the tub is off I will change the rear springs and shocks tomorrow. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Looking good Andrew
![]() Ether thought off offering Land Rover a bid for the production line cos you make a better job than they do ![]() |
![]() ![]() Must say that it would be quicker and easier if I had bought a rolling chassis and the body in kit form. |
Here is a pic showing the 'leg room' that is now available in the second row floor area.
To give a comparison the mat in the foot well is from a 110 ![]() Click image to enlarge |
Leap of faith this afternoon........ measured and measured and measured again before marking out the brand new 90 roof ready to cut off the bit that's not required.
![]() Click image to enlarge Too late now here is the 'off cut' (and Thomas the SpringerBear) ![]() Click image to enlarge Here you go if fits TF ![]() ![]() ![]() Click image to enlarge |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2267 ![]() ![]() |
Great topic and I watch with great excitement to see the finish .
I will be taking the leap of faith ( and the cutter ) to my new 110 2.2 xs csw soon . Going to be daring . Windscreen out and replaced for a split screen Doors off , replaced with series and military tops Hardtop off and replaced with full canvas . Hmmmmm ! |
Starting to get annoying now, not only is the vehicle not square nor is the AFN top
![]() The amount of times I have lifted the new roof on and off is unbelievable, hopefully by the end of the day I will have made the roof to roof adapter plate and the side to side ones. Its booked into the spray shop for next Thursday so I have to get this sorted today ![]() ![]() Click image to enlarge |
