Home > Puma (Tdci) > Lanky & clanky transmission, snatchy take up...
Page 2 of 4 <1234>
Caterham
Dare I ask which dealers you refer to....i wonder if it's been Caterham'd by the same dealers.
New turbo fixed my kangaroo 'ing........
Just wondering.......do you suspect your clutch could be excessively stiff?
As daft as it sounds some lube on mine seemed to help no end - and not necessarily with the stiffness Shocked
Post #335511 3rd Jun 2014 8:31pm
newhue
Australia
Timbar, the death rattle I think Blackwolf is talking about is a definite, unmistakable rattle. I have had this rattle, it's from broken springs in the clutch assembly. I believe the clutch has been upgraded somehow and no longer suffer from breaking springs.
In your youtube clip, what I could hear is normal engine noise pending clutch in or out. Mine does this as well but it's not the dying clutch rattle.
Post #335590 4th Jun 2014 5:36am
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
That's good to know - still getting used to the defender's sound so handy to have a reference point. Cheers. 2009 110 XS Station Wagon
Post #335602 4th Jun 2014 8:02am
timbar wrote:
... Blackwolf, I put a recording of it here: ...
That actually sounds fairly normal to me, it isn't the clutch death rattle.
The best test for the death rattle is to shut off the engine with the clutch in, when the rattle will be unmistakable.
Post #335616 4th Jun 2014 9:02am
timbar
Cheers Thumbs Up 2009 110 XS Station Wagon
Post #335620 4th Jun 2014 9:18am
Fish
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
This pogoing that you can't get out of without dipping the clutch is very similar to what happens when you bypass the clutch switch to get rid of the rev hold. Is this working properly, ie do the revs hold when you change up. If they don't and drop straight back down I'd suggest the clutch switch is knackered and a new one will fix it.... It is a plug located on the top of the clutch hydraulic reservoir. You can shot it out to get rifd of the rev hold but then it Kangeroos and shunts...
Have a look at it and see what it is doing, with a multimeter clutch depressed should give a made contact clutch out ie driving should be open contact...
Hope it helps, at least worth checking...
Post #335808 4th Jun 2014 9:43pm
a13x
I've had vibration/knocking/play in the driveline and has taken 18 months and 5 seperate trips to finally sort. Hopefully fully rectified when the car comes back tomorrow and done so by taking to a different dealer with a fresh pair of eyes.
Originally loose propshaft bolts. Now found worn drive flanges and wear to parts in the transfer box
The first dealer who had it on 4 seperate occasions were never really that interested in looking for a problem but thankfully Sturgess Leicester took only an hour to have a proper look and find the issue.
Good luck and change dealers if in doubt
Post #335817 4th Jun 2014 10:00pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Clutch seems fine and not stiff.
The dealer is Guy Salmon, Knutsford.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #335851 4th Jun 2014 11:26pm
cinstone
The rev' hold is working correctly.
Post #335852 4th Jun 2014 11:27pm
cinstone
I took the comments off here to the dealer today, but nowt's been done on the drive line issues as Land Rover have not changed their mind on it being "satisfactory".
Looks like I may have to change dealers (from Guy Salmon Knutsford), followed by manufacturer!
And I haven't mentioned the other faults, such as the three visits to fix the heater to stop it bleeding past the lower vents when its on screen. It's now almost correct, but on full cold it now blows luke warm, followed by all the sealer that's on the door frames from when they resealed the windscreen, and they still haven't removed it all!
Post #335853 4th Jun 2014 11:38pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Just a thought, have you/they change the throttle pedal potentiometer..? On my TD5 I get a slight pogo effect at low speeds in 2nd/3rd gear and it seems to be a combination of a dead spot on the potentiometer causing the car to slow, which in turn causes my foot to press a little harder on the pedal going past the dead spot but giving it a bit more throttle.
Not sure if that's clear..!
Simon
Ps I've always had great service from Guy Salmon in Stockport, might be worth a visit.
Post #335879 5th Jun 2014 6:46am
cinstone
Although I have no evidence either way to suggest what they have or haven't checked, recent pm's and emails to Mike in LR's customer services and the service manager at Guy Salmon Knutsford gives me the feeling that the basic stuff such as the tightness of bolts, the condition of engine and gearbox mountings, and that sort of thing, may not have been checked, so I doubt the throttle has been looked at. I don't know either way on these checks, but I asked last night via an email to the dealer what had been checked since this was first brought up at the service last September. However, all I got back was that the technician went through in detail what had been done yesterday. This "detail" concerned work done during this last visit, which didn't including anything on the pogoing issue.
Both myself and LRCS are waiting for a reply on what has or hasn't been checked from the dealer.
Regarding the Stockport branch, that's even further away.
Cheers for the extra info' folks.
Post #335973 5th Jun 2014 5:25pm
cinstone
Please let me know how you get on with yours. It may be that Sturgess get my business if they are successful, and I'll save around 30 miles per round trip.
To date I've done over 700 miles to the dealer on this issue (with a few others at the same time) going to and from Guy Salmon Knutsford.
Post #335978 5th Jun 2014 5:30pm
a13x
I should get the car back tomorrow now. There was a delay with a seized bolt and them needing an engineer visit the dealer and resolve. I've no idea who this engineer is or why one is needed but hopefully the car will come back feeling better.
Post #336007 5th Jun 2014 7:46pm
cinstone
Cheers.
Thanks for letting me know.
I've just been on to LRCS again, and the next option will be to take it to another dealer.
Which one in Leicester did you take it too? There seems to be serveral in that area.
On the plus side, going to Leicester will save me 40 miles per round trip.
Post #336164 6th Jun 2014 12:20pm
Page 2 of 4 <1234>
