![]() | Home > Puma (Tdci) > Lanky & clanky transmission, snatchy take up... |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
What have they done to improve things?
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
I would not be in a great rush to take mine back there based on previous experience: http://www.defender2.net/forum/topic25274.html Loose propshaft bolts were one of many things that my local dealership put right at Sturgess' expense. |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 555 ![]() ![]() |
Not good. Problem for me is that a bad experience is almost a given at a LR dealer. The nearest is Derby who damaged the RR when it went in, admitted but then continually ignored attempts to rectify. In the end it wasn't worth the hassle in taking further action.
Stratstone Nottingham became quite comical. I would take 1 car in for warranty work, few days/week later take another in collecting the first and continue this with both cars almost none stop. Each time for the same faults and each time after being assured now rectified, find that they haven't sorted anything at all. The bit that made it less amusing was the 3hr round trip each time. No compensation for fuel, mileage and wasted time ever offered. However for me atleast, Sturgess kept me informed throughout, diagnosed and appears to have sorted the last few issues. I take some responsibility for their valet putting the swirls and scratches in as I forgot for a few days to ask for it to not be washed. Overall, can honestly say I have never experienced such poor service from a brand with a reluctance to resolve ongoing issues, that is with LR themselves and not the last dealer used. However I believe some of this is with the antiquated Defender itself and not the up to date technology used in production of modern cars. If it wasn't for being such an iconic car, could quickly get tired of it and purchase a D4 instead. |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Thanks for the update.
Not sure what to do/where to go now. Premature wear of drive flanges and duff clutches, if this is indeed the problem, has nothing to do with modern technical lecky bits, or the Defender being "antiquated". It's crap parts. I bet my 1964 Series IIa is still on its original drive shafts. LR's stance is the same on the pogoing issue, and the dealer, Guy Salmon Knutsford, for every fault fixed under warranty, it comes back with at least one that wasn't there when it went in! I'm currently assessing mine over the next week or so before deciding what to do next. However, this is my last new(ish) LR, approx' one year before I intended it to be. And it's quite a loss to Land Rover as my last one was to be an XS SW 90 with just about all the available bits and bobs slapped on it, in a sort of last hurrah. But this doesn't bother Land Rover of course. They just want to sell things like Evoques. And they ain't no brilliant car either, after having the use of one for 61 days/3000 miles or so. Rant over. For now ![]() Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
defendercorner Member Since: 17 Feb 2014 Location: Pembrokeshire Posts: 61 ![]() ![]() ![]() |
Hi,
Thought I'd try to resurrect this thread. Had my MY12 2.2 for a few months now and get the slow speed pogo thing and clunky/snatchy gear change. Took it to Likes in Brecon for 24k service and to fix oil leak on bell housing & mentioned the pogoing. They changed the rear crankshaft oil seal and while in there fitted a new clutch kit as they found the spring/s were broken. On drive home I was made up with difference in gear change, smooth & quiet. Only problem was the oil leak was still there ![]() Likes came to collect and after taking a look diagnosed as the oil seal that they changed was defective. Changed seal again and leak now seems to have gone. However the gear change is now back to clunky/snatchy old self ![]() I've spoken to Likes and explained how much better it was and how it's gone worse again. Explanation was maybe improvement was when clutch plate "bedding in" and hence now back to old self. Seems odd to me. Any ideas? Cinstone, Did you ever get yours sorted? Thanks, Tony 2015 90 2.2 XS Hard Top 2012 110 2.2 XS DC 2003 110 TD5 County DC (now sold) |
rover Member Since: 26 May 2012 Location: Yorkshire Posts: 150 ![]() ![]() |
Afetr reading this thread I am afraid it has made me feel slightly better about my own 2.2. Its jerky,juddery,very poor gear change, no torque at low revs and best of all Land Rover can't or more likely won't fix the problem. Looks like I am not suffering alone.
Very occaisonaly the car actually drives Ok this would indicate to me thats its an electrical/sensor/ECU problem. Has any one managed to solve these problems. Remap maybe? |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
I had this, or at least a version of it. Stumbling in first, occasional pogoing, need to try and get high revs in low gears to get any pull at all.
Had a BAS remap - all of these symptoms gone, it is now a pleasure to drive and pulls away with loads of torque from quite low revs. |
Hi,
Thanks for the replies. Well mine is booked back in next Thursday for Likes to take another look. The service manager is going to take it for a drive and see what he thinks. He's been very helpful so far so let's hope he agrees it isn't right. My main thing I'm confused about is why it was so much better when clutch kit 1st put in but then reverted back to its old self when oil seal was changed again? Maybe they didn't bleed the clutch correctly? Any ideas very welcome. Thanks, Tony 2015 90 2.2 XS Hard Top 2012 110 2.2 XS DC 2003 110 TD5 County DC (now sold) |
Hi,
Just thought i'd update on my posts above in case it helps anyone else. Had an excellent service from Likes in Brecon, Terry the After Sales Manager is particularly helpful. After its visit around a week ago the gearchange has improved enormously. Apparently they did manage to bleed the clutch a little so that must have helped and also there is an adjustment on the clutch which they used to raise the biting point on the peddle a little. End result is that the gear change is much improved and i'm very happy ![]() Bonus is that Likes fitted my Mantec RAI as a goodwill gesture and gave me 10% off the adjustable tow bar i needed ![]() Cheers, Tony 2015 90 2.2 XS Hard Top 2012 110 2.2 XS DC 2003 110 TD5 County DC (now sold) |
Smurph Member Since: 29 May 2013 Location: Zimbabwe Posts: 27 ![]() ![]() |
My 2012 110 has the same pogoing characteristic at low speed. It seems that where you want and need the most control you have least!
Improved a bit with an " update " of the ECU by the dealer. |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
I get the pogoing in second on occasion and the only fix for me is not having a constant throttle, generally giving it a bit more works as it usually manifests itself going round a 2nd gear corner.
The only way I can get round the clanking gear changes is to think along the lines of only ever touching the clutch or throttle, never both at the same time so no trying to feed throttle while engaging clutch. Gear changes are then as smooth as you like albeit maybe not as speedy. |
johnbain Member Since: 28 Oct 2012 Location: livingston Posts: 34 ![]() ![]() |
ive had similar and have had so many dealer visits last one got me complete clutch assembly plus an out put shaft dealer says if i return with any more problems relating to this i might need a new gearbox want my 300tdi back which is annoying as ive spent a bit on upgrades Range rover td6
defender2 xtech |
def_fid Member Since: 07 Mar 2011 Location: worcestershire Posts: 17 ![]() ![]() ![]() |
I had the same pogoing, cured by a BAS remap. Clunky drivetrain is normal for a Defender, but does seem worse onmy 2.2 than my old 300 tdi. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
I had my clutch and clunk addressed by Guy Salmon and have just had the paperwork these are they replaced
LLR048731 KIT CLUTCH £217 LLR004390 SLEEVE £37 LLR052128 CYLINDER CLUTCH £66 LIYX500050 RING £11 LKR0500330 SHIELD £30 LLR033026 FLYWHEEL £355 LTUD500020 SHAFT FRONT £43 LLR030054 FLANGE DRIVE £52 LLR006096 BOLT SPECIAL £7 LNY606042 LOCKNUT X12 21P L571752 GASKET So it appears it was my gearbox to transfer box shaft that had the play after about 500 miles the clunk and rattle have not yet come back DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
