Home > Expedition & Overland > Solar charging panels
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
I have recently purchased a trickle charge and a portable 60w solar panel for camping and adventure travel (without mains electricity) The trickle panel feeds via my dianostic socket, to maintain my engine battery and the 60w panel into my dual battery system. I chose a portable 60w panel, rather than a roof mounted permenant fixture to give myself more freedom of use. I would be interested in do's / dont's from other users Cool
Post #321209 3rd Apr 2014 9:09am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
To get the best result from your solar panel in West Sussex the optimum angle of the panel should be 38 degrees facing due South.
Have a play with this http://re.jrc.ec.europa.eu/pvgis/apps4/pvest.php 2007 TD5 90 Hard Top
Post #321258 3rd Apr 2014 2:48pm
trooper
Yes, that is one of the reasons for choosing an adjustable portable panel, to get near to the optimum angle for the location.
Post #321295 3rd Apr 2014 4:22pm
216lcg
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I also have a dual charge system and run an engel fridge on the aux battery. Is it safe and will it work to fit a cigar socket type plug to the solar panel and then recharge the battery via an exisitng cigar socket on the aux battery circuit. Is there any down side to doing this ? Thanks,
Post #335444 3rd Jun 2014 3:04pm
Les Brock
Make sure you use a voltage regulator Thumbs Up
Post #335458 3rd Jun 2014 4:17pm
trooper
Yes providing you have a Solar controller fitted in the circuit, limiting the solar panel output to a maximum of approx. 14.4v
Post #335470 3rd Jun 2014 5:20pm
