![]() | Home > Expedition & Overland > Solar charging panels |
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
I have recently purchased a trickle charge and a portable 60w solar panel for camping and adventure travel (without mains electricity) The trickle panel feeds via my dianostic socket, to maintain my engine battery and the 60w panel into my dual battery system. I chose a portable 60w panel, rather than a roof mounted permenant fixture to give myself more freedom of use. I would be interested in do's / dont's from other users
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
To get the best result from your solar panel in West Sussex the optimum angle of the panel should be 38 degrees facing due South.
Have a play with this http://re.jrc.ec.europa.eu/pvgis/apps4/pvest.php 2007 TD5 90 Hard Top |
Yes, that is one of the reasons for choosing an adjustable portable panel, to get near to the optimum angle for the location.
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 187 ![]() ![]() |
Make sure you use a voltage regulator
Yes providing you have a Solar controller fitted in the circuit, limiting the solar panel output to a maximum of approx. 14.4v
