Home > Technical > Steering wheel boss
landroverdiver
Steering wheel boss
Hi
I have a 53 plate 2004 TD5 station wagon which has the airbag lookalike style steering wheel. Can anyone confirm if it's 36 or 48 spline?
From research on here, I think it's 36.
Obvious answer is to count the splines, but I am in Australia and truck at home in Scotland.
I have bought a momo Nero off ebay and want to order a RDX slimline boss before I get home.
Thanks for any advice.
Mike
Post #333892 27th May 2014 12:19pm
Green Machine
Yep, if it's a genuine CSW with the 'airbag' wheel it's 36 spline. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #333897 27th May 2014 12:43pm
mk1collector
I was under the impression it could be either, but I also have a 2004 53 plate 110 csw and that is 36 spline
Post #333902 27th May 2014 1:31pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Best and probably only way to know for sure is to count them. I believe LR had a habit of fitting what ever was to hand at this time, my 2003 td5 county hardtop has 48...
Post #333908 27th May 2014 2:34pm
MichaelHead
England 2006 Defender 90 Td5 HT Tonga Green
Csw had different no of splines to stop people Turning hard tops into station wagons easily .
Post #333909 27th May 2014 2:41pm
rallysteve
I looked into this a while ago. Any td5 vehicle that was originally based on a Station Wagon platform (this includes the utility wagon but stragely not the double cab pick up) will have the 36 spline column. The 36 spline td5 wheel is the 'airbag' type one. All td5 utility vehicles have the 48 spline column (including dcpu) and have the soft type two spoke wheel with the big oval LR badge in the centre.
The confusion comes with the introduction of the tdci vehicles as an 'airbag' style wheel with 48 splines appeared.
Hope that helps,
Steve
Post #333910 27th May 2014 2:43pm
leeds
I have spoken to people who sell steering wheels and as far as Defenders are concerned there is no rhyme or reason to number of splines in the steering boss.
Simple answer is either to count splines or take a measurement IIRC 17mm = 36 splines 19mm = 48 splines.
Some companies sell steering wheels with two bosses and you get a refund on one boss when you return it.
So best advice is to either count/measure the steering column
Alternative is get both bosses with an agreed refund on the one you do not need.
Brendan
Post #333915 27th May 2014 3:11pm
landroverdiver
Steering wheel boss
Answers much appreciated guys.
Post #334038 27th May 2014 10:01pm
Green Machine
As rallysteve says above - the whole steering wheel splines issue has a reputation as a complete dark art, but it actually isn't. If it's the 'two spoke' wheel as fitted to utility Defenders (lower specs) it's 48 spline. If it's the 'airbag' type on a Td5, it's 36 spline. The problem arises with early Pumas (2007 vintage) where they switched over to a 48 spline column for the 'airbag' wheel as well, but used up the remaining 36's first. So that period with the 'airbag' type wheel could be either and you have to check. But for any other vintage you can be sure what you've got just by the steering wheel. For reference - all Pumas after 2007-2008 are 48 spline whether they're 'two-spoke' or 'airbag' wheel. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #334074 28th May 2014 12:14am
forever
How many would a 85 90 have, thinking of changing my steering wheel too Smile
Post #341015 26th Jun 2014 5:31pm
Green Machine
Has it got the 4 spoke steering wheel with square boss? If so, it's 36. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #341029 26th Jun 2014 7:07pm
Martin
Site Admin
A page of mine from long ago: http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels
There is a logical pattern, well there is until LR introduced a 48 spline CSW wheel in 2009ish Thud Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #341053 26th Jun 2014 8:58pm
forever
Thanks so mine will be 36,
Post #341758 30th Jun 2014 10:10am
See my thread here <--- on how I made a boss out of an old 4 spoke wheel (36 spline)
Post #341891 30th Jun 2014 8:02pm
