![]() | Home > Technical > Steering wheel boss |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Yep, if it's a genuine CSW with the 'airbag' wheel it's 36 spline.
I was under the impression it could be either, but I also have a 2004 53 plate 110 csw and that is 36 spline
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 630 ![]() ![]() ![]() |
Best and probably only way to know for sure is to count them. I believe LR had a habit of fitting what ever was to hand at this time, my 2003 td5 county hardtop has 48...
MichaelHead Member Since: 16 Jul 2012 Location: Bucks Posts: 116 ![]() ![]() ![]() |
Csw had different no of splines to stop people Turning hard tops into station wagons easily .
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I looked into this a while ago. Any td5 vehicle that was originally based on a Station Wagon platform (this includes the utility wagon but stragely not the double cab pick up) will have the 36 spline column. The 36 spline td5 wheel is the 'airbag' type one. All td5 utility vehicles have the 48 spline column (including dcpu) and have the soft type two spoke wheel with the big oval LR badge in the centre.
The confusion comes with the introduction of the tdci vehicles as an 'airbag' style wheel with 48 splines appeared. Hope that helps, Steve |
I have spoken to people who sell steering wheels and as far as Defenders are concerned there is no rhyme or reason to number of splines in the steering boss.
Simple answer is either to count splines or take a measurement IIRC 17mm = 36 splines 19mm = 48 splines. Some companies sell steering wheels with two bosses and you get a refund on one boss when you return it. So best advice is to either count/measure the steering column Alternative is get both bosses with an agreed refund on the one you do not need. Brendan |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Answers much appreciated guys.
As rallysteve says above - the whole steering wheel splines issue has a reputation as a complete dark art, but it actually isn't. If it's the 'two spoke' wheel as fitted to utility Defenders (lower specs) it's 48 spline. If it's the 'airbag' type on a Td5, it's 36 spline. The problem arises with early Pumas (2007 vintage) where they switched over to a 48 spline column for the 'airbag' wheel as well, but used up the remaining 36's first. So that period with the 'airbag' type wheel could be either and you have to check. But for any other vintage you can be sure what you've got just by the steering wheel. For reference - all Pumas after 2007-2008 are 48 spline whether they're 'two-spoke' or 'airbag' wheel. 2005 Td5 | 90 Station Wagon | Tonga Green
forever Member Since: 16 Dec 2013 Location: Surrey Posts: 72 ![]() ![]() |
How many would a 85 90 have, thinking of changing my steering wheel too
Has it got the 4 spoke steering wheel with square boss? If so, it's 36. 2005 Td5 | 90 Station Wagon | Tonga Green
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
A page of mine from long ago: http://www.web-rover.co.uk/nav.php?p=articles/steeringwheels
There is a logical pattern, well there is until LR introduced a 48 spline CSW wheel in 2009ish ![]() ![]() ![]() ![]() |
Thanks so mine will be 36,
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
See my thread here <--- on how I made a boss out of an old 4 spoke wheel (36 spline)
