Home > In Car Electronics > Kenwood or Alpine? |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Having failed last night to get the HU and it's gubbins to fit in so that the HU sat flush, I thought I would have another go tonight. Once again having tired many strategies, I resorted to taking it out and putting it back in the hope that the plugs would just happen to fall into the right place on their own. This didn't work either....until I gave up shoved it back in...and ta-da the plugs DID just happen to fall into the right place on their own!
Happy days! Thanks Steve and Jimbob, that's a fiver saved on a nasty spacer! |
24th May 2014 7:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19654 |
Good job! Touch wood you have no troubles from trapped wires now.
What plugs was it? |
24th May 2014 8:04pm |
Did think about trapped wires.....but it is all working! It actually slid in dead easy this time. The plugs in question are the ISO plugs. The loom has ISOs and so I have used a Kenwood DIN to ISO adaptor (found 1 for £3.99 on eblag). This only had about 6 inches of cable between the DIN and ISO which I think caused the problem!
24th May 2014 8:26pm |
Yes, they can be rather chunky to say the least. Glad it's sorted anyway.
24th May 2014 9:01pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Pov.spec,ftw. 2006, 110,TD5.
24th May 2014 9:29pm |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 |
Not sure if you got your speakers sorted, but i fitted a pair of component Focal speakers that have the tweeters on top of the dash and then they wire into the main 4" mid range under the dash. They sound great, however they do come at a cost!! In fact they are some of the best speakers i have heard.
25th May 2014 7:59am |
No I haven't done that yet......it is at the bottom of a list of things now, underneath all the things that need doing .
25th May 2014 5:54pm |
I am fairly certain that theses are what I had in my previous 110:
http://www.maplin.co.uk/p/4-inch-102cm-coa...kers-l20at Cheap and cheeerful but were much better than the ones it came with! |
29th May 2014 1:40pm |
