Home > Puma (Tdci) > Winter Wheels and Tyres - Advice please
90mojo
Have been reading up on the threads about tyre options for Winter and steel wheels.
Concluded so far it will be a useful thing to do given most of my travelling for work is rural back roads in North Yorkshire.
So.. thinking of Goodyear Duratrac (265's?) on 16" Wolf rims.
My Landy came with Boosts. As a newbie I'm a bit unsure about HD steel rims versus (STD?) and what will/will not fit on the wheel studs that are standard with Boosts on a 90 XS
Advice greatly appreciated. I'll be happy if I can just stay on the road during Winter and have no plans to offroad Smile If there's an option better than Wolf's please do say. I'd rather buy quality than save on price by buying something lesser as I'm wanting the vehicle to be a keeper so I plan to have any extras I buy for a long time. Recommendations on rim and tyre sizes also appreciated
Post #332771 22nd May 2014 1:36pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Hi, if you're going to go for 265's then Wolf's might be a little narrow, I think they're all 16 x 6.5 and for a 265 ideally you'd be looking at 7 or 8 inch width, so maybe go for a good quality modular. As for Duratrac's, I've got them on mine (265's on 7" Zu rims) and they are great, quiet on tarmac, good in snow and mud, look chunky and give good levels of grip on anything I've driven on so far. I'd recommend them.
Post #332772 22nd May 2014 1:53pm
ericvv
Post #332778 22nd May 2014 3:21pm
Martin
Site Admin
I would go narrower than 265 (i.e. 235) for a dedicated winter tyre, although having said that I'm a hypocrite and have 265 BFG ATs on the 90 and find them excellent in the winter Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #332785 22nd May 2014 4:09pm
jimbob7
As above, narrow tyres,which are better in the snow. Pov.spec,ftw. 2006, 110,TD5.
Post #332795 22nd May 2014 4:23pm
90mojo
Thanks for the prompt (and friendly as always) replies,
Was beginning to think I was overdoing it with 265's - brainblock as I'm on 235's with the Boosts -
So, errmmm Embarassed 235's on Wolfs?
Post #332806 22nd May 2014 4:56pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I see from your profile that your defender is new, I would be inclined to see how it goes on the factory fit tyres before spending a lump of cash on something you may not need.
As above thumbs up for BFG A/Ts I have used them for years on different Defenders both 265 and 235 and never had cause for complaint. 2005 Td5 90 XS
Steve
Post #332807 22nd May 2014 4:58pm
Cooper snows or nokians, 235's Thumbs Up
Post #332808 22nd May 2014 4:58pm
jimbob7
True/\/\/\,winter tyre's have a maximum operating temp of +7deg.C,its been very mild this year and fitting winter tyres would not have been worth it,the all season,all terrain, standard fit Conti's are fine in all but the most extreme cold,snowy conditions. Pov.spec,ftw. 2006, 110,TD5.
Post #332822 22nd May 2014 5:48pm
ericvv
^^ max operating temp of 7°C? Not really true. The tire industry for the last 10 years has discovered the ever again used argument that summer tires rubber hardens below 7°C and then become less efficient. Winter tires are supposedly a softer rubber/silicone mix which remains flexible below this 7°C... How much truth and how much sales pitch in that statement, I don't know... But there is nobody who says that winter tires would have a max operating temp of 7°C, they will function well at 10 or 15 or 20°C... Probably will loose a bit more thread at 20°C than a summer tire would, but that's it as to effects of running them in the summer. In my opinion the main advantage in the winter of winter tires are the multiple incisions in the thread which make them adhere better in the snow, and they usually make also an excellent rain tire.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #332824 22nd May 2014 5:56pm
jimbob7
Softer compound winter tyres will wear quicker than usual (or melt) at higher operating temps,hence the recommended 7deg.C maximum operating temps AND slower speed ratings.
The softer compound winter tyres allows the tyre to move about and get up to operating temperature,its the heat that gives tyres grip,ask any motorcyclist,nothing worse for grip than a cold tyre.Overheating also damages tyres,which is the main reason for not using winter tyres when it's warm. Pov.spec,ftw. 2006, 110,TD5.
Post #332826 22nd May 2014 6:01pm
Normal car on Winters in the summer = slides and poo braking
Post #332827 22nd May 2014 6:06pm
ericvv
Couple questions/comments to above statement....
wear quicker,... agree, that is what I said too.
or melt? Shocked any hard litterature to subtantiate that? (never heard of a melting winter tire if normally used in summer)
hence the recommended 7°C max operating temps.... where can I read that?
slower speed rating... speed rating just depends on how much money you pay, you have winter tires with same rating as summer tires
By the way, the Swiss are no fools when it comes to safety, but are quite pragmatic too, hence the common sense recommendation here in a country where virtually every car has a set of summer wheels/tires and a set of winter wheels/tires, is that winter tires should not be run down to the legal 1.6mm thread depth, but only to 3.0mm, and if you get to about that thread depth at the end of a winter season, then run them a last summer season as at about 3mm thread depth they will be fine for one more summer, and then come October buy a new set of winter tires... So you effectively save your summer wheels/tires one season then while still getting the last acceptable use out of your winter tires. Which on dealer recommendation is effectively what we are doing with my wife's VW this summer, her summer wheels/tires stay in storage, and a last summer season on her winter tires which after 8 years are down to 4mm now, and then new winter tires before the next winter....
Post #332831 22nd May 2014 6:34pm
90mojo
Big Cry Really wanted to get some useful advice about what Wolf wheels go with std studs I've got
Big Cry Know I should've said 235's
4WD's I've had before pull away really well in the snow (LR/Isuzu/Subaru/Ford)......but don't stop very well
Help Big Cry
....... Big Cry
........ Big Cry
Very Happy
Post #332853 22nd May 2014 8:27pm
90mojo
Did I say that out loud? Embarassed
Post #332871 22nd May 2014 9:23pm
