![]() | Home > Puma (Tdci) > swivel housing grease question |
| CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558
I got one tube of grease from the dealers and opened up the filler plugs to have a look see.
I placed a yellow piece of wire down to the bottom of the housing and it came back with a decent coating of grease on the bottom end. Would it be a bad idea to add half a tube on each side as piece of mind or better left alone. Not sure if it's better over or underfull - I know in a bearing situation there must be an air gap for heat transfere but in this case it's similar to splash lubrication I guess. Any opinions |
when I originally changed the diff oil it was mixed with water and had some lumps of what felt like grease in the oil.
The swivel seals allow a very slight bit of grease on the balls but I wouldn't say they are leaking as such that it makes a huge mess. Would topping up not do any harm if one cannot gauge a level in any reliable means |
| parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366
When i did my discovery swivels i filled them right to the top with the grease tubes supplied by Land Rover. I've not had any leaks or other problems in the three years since. 130 crew cab
98 V8 Disco |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803
Fill 'em up, does no harm that I know of, always done it this way
Thanks guys - that's what I wanted to hear.
Will do |
| All times are GMT |
