Home > Puma (Tdci) > swivel housing grease question
CapeLandy
South Africa
I got one tube of grease from the dealers and opened up the filler plugs to have a look see.
I placed a yellow piece of wire down to the bottom of the housing and it came back with a decent coating of grease on the bottom end.
Would it be a bad idea to add half a tube on each side as piece of mind or better left alone.
Not sure if it's better over or underfull - I know in a bearing situation there must be an air gap for heat transfere but in this case it's similar to splash lubrication I guess.
Any opinions
Post #33182 28th May 2010 3:44pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
This is what I would do:
1. Check the ooil in the front diif, if it is a milky colour that means grease may have leaked from the swivel housing (not uncommon).
2. Depending on the answer to #1 replace the front diff oil and top up the swivels
3. Top up swivels if the swivels ball seals are leaking
Thumbs Up 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #33183 28th May 2010 3:54pm
CapeLandy
South Africa
when I originally changed the diff oil it was mixed with water and had some lumps of what felt like grease in the oil.
The swivel seals allow a very slight bit of grease on the balls but I wouldn't say they are leaking as such that it makes a huge mess.
Would topping up not do any harm if one cannot gauge a level in any reliable means
Post #33186 28th May 2010 4:00pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
When i did my discovery swivels i filled them right to the top with the grease tubes supplied by Land Rover. I've not had any leaks or other problems in the three years since. 130 crew cab
98 V8 Disco
Post #33192 28th May 2010 7:08pm
CFB
Fill 'em up, does no harm that I know of, always done it this way Thumbs Up Andy
Post #33193 28th May 2010 7:27pm
CapeLandy
South Africa
Thanks guys - that's what I wanted to hear.
Will do
Post #33201 28th May 2010 11:18pm
