Home > Technical > Bonding glue
excossack
Bonding glue
What do LR use to bond the door panel to the frame? I notice when I shut the drivers door the outer skin rattles as if it the bonding has gone. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #331666 17th May 2014 10:19pm
bear100
My passenger door does the same Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #331685 17th May 2014 11:44pm
mk1collector
Take the door card off and water shedder, push out the door skin and squirt sikaflex in between the frame and skin every place you can get a sealer gun in, then lightly press the door skin from the outside to squeeze the sikaflex into place and leave for an hour. Rebuild the door (not forgetting to replace the water shedder) and by the next morning you should have a more reassuring thud when shutting the doors.
Post #331687 18th May 2014 12:12am
bear100
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #331708 18th May 2014 8:34am
excossack
Thanks Mk1 collector. Water shredder - is that the plastic sheet glued to the door frame? 1999 Defender TD5 110
Regards
John M0VAZ
Post #331720 18th May 2014 9:37am
mk1collector
Yeah that's it. It's quite important to keep water out of the car so make sure you put it back and if there are any rips in it, it's best to get a new one which are only a few quid from main dealers
Post #331727 18th May 2014 9:56am
excossack
Ahh right. I was thinking of replacing the plastic sheets as the one got damaged when removing it off the door I have repaired. 1999 Defender TD5 110
Regards
John M0VAZ
Post #331748 18th May 2014 11:31am
