![]() | Home > Technical > Bonding glue |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
My passenger door does the same
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Take the door card off and water shedder, push out the door skin and squirt sikaflex in between the frame and skin every place you can get a sealer gun in, then lightly press the door skin from the outside to squeeze the sikaflex into place and leave for an hour. Rebuild the door (not forgetting to replace the water shedder) and by the next morning you should have a more reassuring thud when shutting the doors.
![]() ![]() ![]() ![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6012 ![]() ![]() ![]() |
Thanks Mk1 collector. Water shredder - is that the plastic sheet glued to the door frame? 1999 Defender TD5 110
Yeah that's it. It's quite important to keep water out of the car so make sure you put it back and if there are any rips in it, it's best to get a new one which are only a few quid from main dealers
Ahh right. I was thinking of replacing the plastic sheets as the one got damaged when removing it off the door I have repaired. 1999 Defender TD5 110
