Page 681 of 1394 <123 ... 680681682 ... 139213931394>
tried out my HM 1.6 delux Whistle
Post #330358 11th May 2014 8:32pm
buellbeast
 2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Removed all the extras ready to trade it in. Big Cry
Post #330362 11th May 2014 8:39pm
Martin 01
Changed both oil filters & oil in my Td5.
Put in some TSL I had left over.
Replaced the loom last week.
Had new injector seals fitted Friday.
All is well at the moment Thumbs Up
Post #330374 11th May 2014 9:05pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
davidwhittaker wrote:
Aren't they fitted in with a plug?bshpuld be able to unplug it & replace
Hmm, not sure; the innards are a plugin fix but as far as I can see you'd have to take the housing off to get it out anyway -- and the bolts used to mount it were badly corroded.
But I might be missing your point, tricky without photos. I'll see if I can start a thread on it after getting some photos int he daylight. 2009 110 XS Station Wagon
Post #330387 11th May 2014 9:23pm
SkyFallSilver
Kuwait
Fitted Nolden BI LED Headlamps
 2016 Defender 90 Adventure Edition
Post #330390 11th May 2014 9:28pm
smb
Finally got round to changing all the suspension(springs & shocks) to Old Man Emu and all bushes to SuperPro. Ride & handling so much better Thumbs Up especially when towing. Sankey now sits level...ish.
Post #330398 11th May 2014 9:46pm
SkyFallSilver
Kuwait
A Bar Install
Post #330554 12th May 2014 4:56pm
Waldo
Although technically it was yesterday.
Completely rebuilt/ refurbed both swivel balls and installed m gywn lewis steering bars.
Had an issue with the bars, appears the thread on one end wasn't tapped again after being galved so the track rod end would only go half way in.
Had to make a makeshift tap out of the track rod ends from the original bar
Long story short it was a nightmare but they are on, albeit the one with he defect is almost impossible to rotate.
Will ring gywn to let him know tomorrow I think. Defender 90 XS TD5 (03 Reg)
Post #330555 12th May 2014 5:02pm
SailingTom
Earlier on today. Got my new to me twisted 18's back on after being repainted limestone cream. Thumbs Up Defender puma dormobile camper
Post #330565 12th May 2014 5:39pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I just did the best mod of 2014 and it was free!
Got fed up with the rear view mirror. It's of no use in the 130 and it was only blocking my view in corners. Removed it and threw it in the cubby box. It's an unsorted mess there already anyways... Rolling Eyes
Post #330608 12th May 2014 7:43pm
mk1collector
Rang the local office of the bus that ran into me over a week ago to try and get insurance info again and still no joy Twisted Evil a trip to the plod station for not supplying insurance details may be on the cards Rolling Eyes
Post #330634 12th May 2014 8:28pm
pob1968
Just fitted a set of steel modulars with Cooper discoverer stt tyres, looks awesome now! bring on the mud Smile 110 Hardtop
Post #330635 12th May 2014 8:30pm
timbar
Just did a very quick test of the aerial extension mod to increase the key fob range, and it works very nicely. It might even work for a while if I can do it properly after picking up a connector tomorrow -- none to hand. 2009 110 XS Station Wagon
Post #330667 12th May 2014 9:20pm
shaggydog
Fitted my new turbo hoses.
Was surprised how much oil there was in the pipes, no wander they were soggy and spongy.
Have noticed though my reliable old 200Tdi has developed a bit of a knock. Not nasty sounding just sounds like a low thudding noise from mid/rear of the engine so will run it for a while and see if it gets worse.
Bit of traction engine thinking, if you hear an unfamiliar noise, listen to it for a hour, its now familiar! If it doesn't last a hour because it went away- problem solved, if it broke, then you know it was a problem which case it is now self evident and can be fixed!
Post #330670 12th May 2014 9:58pm
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
fitted a rear Step bumper NAS style Smile
Post #330795 13th May 2014 6:45pm
