![]() | Home > Maintenance & Modifications > Axle stands |
if you want to get under land rover while on stands I would not go for folding , the legs are very thin metal and I have seen one buckle
I have been under a land rover laying flat on my back when a land rover (discovery) somehow went side ways and came off the axle stands , it was on four stands but were at full extension , the gearbox cross member bounced down as it landed on the floor just touching my chest ,luckily all 4 wheels were still on it , if no wheels it would have been a different story it was one of them moments went it all seems to move slowly and you think "mmm is this it " yes they were folding ones but heavy duty ones my advice is go for solid ones with a wide base and longer then you need , and don't go full extension (it makes the stem loose in the tubes |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Thanks....
I still got the offending stands if you want them cheap
![]() couple them have slight kink in the stem!!! funny they not been used lately |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
I bought these recently: http://www.halfords.com/webapp/wcs/stores/...;langId=-1 http://defender90xs.blogspot.co.uk/
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Have a look here - I'm tempted to get some stands form here
http://www.sgs-engineering.com/hydraulic-jacks/axle-stands |
I bought 3 ton ratchet stands off the bayE for about £20 delivered, but you can get the same generic ratchet stands in Costco fer £20. Pov.spec,ftw. 2006, 110,TD5.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
Bought these from Machine Mart fantastic quality and have never let me down strong as a tank
3 Ton £22.19 http://www.machinemart.co.uk/shop/product/...xle-stands 6 Ton £35.98 http://www.machinemart.co.uk/shop/product/...xle-stands |
Is that 3 tonnes each stand or for the pair?
Yeah thanks Munch...I think I'll pass....
![]() The Halfords ones and sgs ones look up to whatt I want...and I hadn't thought of machine mart! Thanks all. |
3 ton per pair. Pov.spec,ftw. 2006, 110,TD5. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I've had Halfords ones for years.
DO NOT USE FOLDING ONES or RATCHET ONES |
Opie oils (site sponsor) have an offer on all axle stands at the moment and with the forum discount you may pick up a bargain
How do you get the forum discount?
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
I got mine from SGS and they are well made and have been using them recently to swap the springs over. _______________________________ Puma Defender 90 |
