Home > Maintenance & Modifications > Axle stands
kipperthedog
Axle stands
I am after a set of axle stands for occasional use. I am wary of cheap rachet types, but don't want to spend a fortune. Has anyone tried the Sealey folding ones? I am thinking asf2000 or asf3000. these are not too pricey and won't take up a lot of room. I also need something that will do the Subaru as well so don't want anything maaasive!
Post #329948 10th May 2014 5:47pm
munch90
if you want to get under land rover while on stands I would not go for folding , the legs are very thin metal and I have seen one buckle
I have been under a land rover laying flat on my back when a land rover (discovery) somehow went side ways and came off the axle stands , it was on four stands but were at full extension , the gearbox cross member bounced down as it landed on the floor just touching my chest ,luckily all 4 wheels were still on it , if no wheels it would have been a different story
it was one of them moments went it all seems to move slowly and you think "mmm is this it "
yes they were folding ones but heavy duty ones
my advice is go for solid ones with a wide base and longer then you need , and don't go full extension (it makes the stem loose in the tubes
Post #329956 10th May 2014 6:15pm
kipperthedog
Thanks.... Shocked ....I have gone off the idea of folding ones already!
Post #329959 10th May 2014 6:20pm
munch90
I still got the offending stands if you want them cheap Laughing
couple them have slight kink in the stem!!!
funny they not been used lately
Post #329963 10th May 2014 6:24pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Post #329968 10th May 2014 6:28pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Have a look here - I'm tempted to get some stands form here
http://www.sgs-engineering.com/hydraulic-jacks/axle-stands
Post #329970 10th May 2014 6:31pm
jimbob7
I bought 3 ton ratchet stands off the bayE for about �20 delivered, but you can get the same generic ratchet stands in Costco fer �20. Pov.spec,ftw. 2006, 110,TD5.
Post #329983 10th May 2014 6:46pm
gilarion
Bought these from Machine Mart fantastic quality and have never let me down strong as a tank
3 Ton �22.19
http://www.machinemart.co.uk/shop/product/...xle-stands
6 Ton �35.98
Post #329984 10th May 2014 6:50pm
kmac
Is that 3 tonnes each stand or for the pair?
Post #329985 10th May 2014 6:50pm
kipperthedog
Yeah thanks Munch...I think I'll pass.... Very Happy .
The Halfords ones and sgs ones look up to whatt I want...and I hadn't thought of machine mart! Thanks all.
Post #329987 10th May 2014 6:56pm
jimbob7
3 ton per pair. Pov.spec,ftw. 2006, 110,TD5.
Post #330010 10th May 2014 7:54pm
Romadog
I've had Halfords ones for years.
DO NOT USE FOLDING ONES or RATCHET ONES
Post #330017 10th May 2014 8:14pm
mk1collector
Opie oils (site sponsor) have an offer on all axle stands at the moment and with the forum discount you may pick up a bargain Thumbs Up
Post #330021 10th May 2014 8:19pm
kmac
How do you get the forum discount?
Post #330034 10th May 2014 8:44pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
I got mine from SGS and they are well made and have been using them recently to swap the springs over. _______________________________
Puma Defender 90
Post #330035 10th May 2014 8:46pm
