Home > For Sale & Wanted > puma center silencer removal pipe (now got one)(dosnt fit)
LR90XS2011
Any sponsors or members selling a 90 Puma centre silencer replacement pipe £65 quid ( all in from Defender Bits) is the best I can find on the net
thanks in advance DEFENDER 90 TDCI XS,
Post #329728 9th May 2014 6:51pm
SailingTom
Im also after one if any site sponsors fancy a group type buy Thumbs Up Defender puma dormobile camper
Post #329737 9th May 2014 7:31pm
LR90XS2011
sorry im too impatient and ended up getting one from Landy Spare Parts for £61.55 delivered (Terrafirma part) DEFENDER 90 TDCI XS,
Post #329740 9th May 2014 7:34pm
SailingTom
No worries can you pm me a link please as seems good value and cant seem to find it? Very Happy
Many thanks Tom Defender puma dormobile camper
Post #329742 9th May 2014 7:37pm
I have the Terrifirma, I find the fit isn't great, unless it's just me!
Fits but a bit out. Neutral
Post #329743 9th May 2014 7:38pm
LR90XS2011
sales@landyspareparts.com (sales@landyspareparts.com)
http://www.landyspareparts.com
cant recommend yet as first time used and parts still awaited
all the best Rob DEFENDER 90 TDCI XS,
Post #329819 10th May 2014 6:53am
LR90XS2011
well mine arrived a couple of days ago, so I took the original silencer off to find that the replacement one has its mounting brackets in the wrong positions the front 1 hitting the transfer box and the rear one welded 1.5 inches too far forward.
I will be contacting the supplier for a return and refund, but expect that will be postage at my cost.
Based on my experience and the above from custom90steve I would avoid this make of replacement pipe unless you have the patience to cut off the mounting brackets and the equipment to re-weld them on in the correct places.
I have now refitted the original silencer and will be looking elsewhere.
DOH Crying or Very sad DEFENDER 90 TDCI XS,
Post #333418 25th May 2014 10:20am
Oh dear, as I mentioned mine fits but not well!
The locations you mention are only just clear on mine, one day I'll get shot too. Does anyone know what centre killer has?
Terrifirma are rubbish and although I have one myself I wouldn't recommend either.
Post #333428 25th May 2014 11:08am
K9F
Whilst there are several stainless steel exhaust manufacturers and suppliers readily available to sell you their wares, each professing perhaps to be the best, have you considered just replacing the whole kit and kaboodle? I did and I got rid of the rear silencer the centre 'offset' one was replaced with a cylindrical straight through one. It needn't cost as much as you may expect and it comes with a lifetime warranty. Shop around you can also fit them yourself easy enough on your drive without jacking.
Centrebox shown to the left of this picture.......
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333429 25th May 2014 11:09am
There is a lot more options available now too, and AFAIK since the intro of the 2.2 the prices are going down a touch.
Post #333431 25th May 2014 11:11am
LR90XS2011
Thanks Mal / Steve
I have had a look on the net and do fancy the Alive stainless exhaust from the front pipe back, however I have just took on a big mortgage and the Mrs would not be too happy with me spending £500 we have not got.
If anyone can recommend an affordable alternative I will look into that would be great.
I'm a bit Censored with Allmakes Terrafirma as this is the second thing I have purchased that does not fit, and there is no excuse for such shoddyness. The first was corner protectors that were welded up off square and hit the rear panels, I ended up returning them to the suppliers as well. Everything else I have ever purchases for the Landy has fortunately fitted well. DEFENDER 90 TDCI XS,
Post #333435 25th May 2014 11:23am
If you just wanted a mid section I'm sure Gary at Alive or IRB could sort you out with a phone call. At least for now anyway. Thumbs Up
Post #333444 25th May 2014 12:59pm
K9F
If they'll fit. The OEM centrebox has triangular flange at one end with three studs, a round one at the other with two. From pictures depicted on the Alive Boutique theirs doesn't but the flanges do indeed appear to be there. They may be able to make one but I suspect (but may be wrong) it's all or nothing with regards to the remainder of the exhaust system whoever you go with. You'll need to find out if the centrebox section is the same length as an OEM one and if you can just swap out that single section.
The studs could of course be replaced with bolts and you may be able to 'adapt' and engineer it to fit! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333454 25th May 2014 1:45pm
