![]() | Home > For Sale & Wanted > puma center silencer removal pipe (now got one)(dosnt fit) |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
Any sponsors or members selling a 90 Puma centre silencer replacement pipe £65 quid ( all in from Defender Bits) is the best I can find on the net
thanks in advance DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 25th May 2014 10:24am. Edited 3 times in total |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
Im also after one if any site sponsors fancy a group type buy
sorry im too impatient and ended up getting one from Landy Spare Parts for £61.55 delivered (Terrafirma part) DEFENDER 90 TDCI XS,
No worries can you pm me a link please as seems good value and cant seem to find it?
Many thanks Tom Defender puma dormobile camper Last edited by SailingTom on 9th May 2014 7:44pm. Edited 1 time in total |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
I have the Terrifirma, I find the fit isn't great, unless it's just me!
Fits but a bit out. |
sales@landyspareparts.com (sales@landyspareparts.com)
http://www.landyspareparts.com cant recommend yet as first time used and parts still awaited all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
well mine arrived a couple of days ago, so I took the original silencer off to find that the replacement one has its mounting brackets in the wrong positions the front 1 hitting the transfer box and the rear one welded 1.5 inches too far forward. I will be contacting the supplier for a return and refund, but expect that will be postage at my cost. Based on my experience and the above from custom90steve I would avoid this make of replacement pipe unless you have the patience to cut off the mounting brackets and the equipment to re-weld them on in the correct places. I have now refitted the original silencer and will be looking elsewhere. DOH I hope everyone is well and your land rovers make you happy |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Whilst there are several stainless steel exhaust manufacturers and suppliers readily available to sell you their wares, each professing perhaps to be the best, have you considered just replacing the whole kit and kaboodle? I did and I got rid of the rear silencer the centre 'offset' one was replaced with a cylindrical straight through one. It needn't cost as much as you may expect and it comes with a lifetime warranty. Shop around you can also fit them yourself easy enough on your drive without jacking.
Centrebox shown to the left of this picture....... Click image to enlarge Treat every day as if it is your last....one day you will be right!! |
There is a lot more options available now too, and AFAIK since the intro of the 2.2 the prices are going down a touch.
Thanks Mal / Steve
I have had a look on the net and do fancy the Alive stainless exhaust from the front pipe back, however I have just took on a big mortgage and the Mrs would not be too happy with me spending £500 we have not got. If anyone can recommend an affordable alternative I will look into that would be great. I'm a bit I hope everyone is well and your land rovers make you happy |
If you just wanted a mid section I'm sure Gary at Alive or IRB could sort you out with a phone call. At least for now anyway.
If they'll fit. The OEM centrebox has triangular flange at one end with three studs, a round one at the other with two. From pictures depicted on the Alive Boutique theirs doesn't but the flanges do indeed appear to be there. They may be able to make one but I suspect (but may be wrong) it's all or nothing with regards to the remainder of the exhaust system whoever you go with. You'll need to find out if the centrebox section is the same length as an OEM one and if you can just swap out that single section.
The studs could of course be replaced with bolts and you may be able to 'adapt' and engineer it to fit! Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
