![]() | Home > My Defender > DarthFender TD5 110 |
Jambo Member Since: 30 Apr 2014 Location: Sunny somerset Posts: 13 ![]() ![]() |
[quote
Flip key http://www.defender2.net/forum/topic23588.html or 1 piece? http://www.defender2.net/forum/topic16546.html [/quote] Spot on ! ![]() Last edited by Jambo on 8th May 2014 8:26pm. Edited 1 time in total |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Both links above have mini how to's
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Where'd you get the MLV from?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20975 ![]() ![]() |
Looks good (photos on previous page) Amp should be okay but make sure nothing else goes under there.
Could do with some washers or something to give a gap between the mounting and Amp. Remember heat rises. Looks good though. ![]() |
Ebay
http://www.ebay.co.uk/itm/Dodo-Barrier-MLV...1151209513 Need 4 sheets 1 per footwell 1 over the plastic transmission tunnel 1 cut up and used behind fuse box / pedals / lower dash |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
ive got 10 sheets of it waiting to go in!!! i went for the stuff with the CCF attached! im doing all of the 110 floor with it!. and eventually a wrights of road matt, from Drew not a cheap project this sound proofing! My 109 thread
my youtube channel |
It's good stuff though
Forgot to change name, marriage has been a bit rocky for me and Mrs Tiger recently due to shared use of 'Darth'
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Sure it's not using the dining table as a work bench that's to blame?
I'm sure that all will be well again on Saturday, Matt
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yep, getting close now.
How much difference does it make to the racket (I know this is subjective).
Mine are currently dampered, awaiting CCF, but haven't got onto the MLV layer yet. |
Can't really say as I've not tested between layers.
I will have some before and after DB readings though when I take it out next |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
that's more space than it looked like it had, should be ok there then ![]() |
