![]() | Home > Puma (Tdci) > Location of inertia switch |
No inertia switch on Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
wtf is an inertia switch?
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
if you smash your Td5, the inertia switch would kill the engine. You could only restart after you reset that switch. IIRC? |
Same thing that senses an impact and sets off airbags (in any other vehicle that is!). ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
ah, cool. funny thing with the anti-stall you'd think they'd have had an inertia switch fitted. when my clutch packed up i had a scary time trying to stop the beast!, had to turn off the ignition (fortunately before i hit the wall - might have pushed the wall over!). www.ralton.co.za
I misunderstood - it measures rapidly decreasing speed. It's not a manual switch (like the kill button on a motorcycle) to stop the engine.
Ignore my previous post... www.ralton.co.za |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
The switch on the Td5's has a small ball beearing inside it (if you take one off and shake it, you can hear it rattle around), like was said, a rapid deceleration (and maybe a "thump" at the end of it) will cause said ballbearing to jump out of its socket and kill the ECU & engine.
It's obviously well designed, as general off road use never seems to trigger it. Just looked through microcat, and indeed, there isn't one listed for puma's. |
bartv Member Since: 03 Oct 2010 Location: Belgium Posts: 12 ![]() |
Is there another system (instead of the inertia) that will cut the fuel after a crash?
And does it only cut the fuel or does it more? My roll-ver defender is not getting any fuel, but it does start when I give it fuel straight to the engine. |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 ![]() ![]() ![]() |
Bart,
Did you check if the fuel pump is doing what it's supposed to do ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Is it a Puma or Td5? ![]() ![]() |
Puma
