![]() | Home > Puma (Tdci) > Location of inertia switch |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
No inertia switch on Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153
wtf is an inertia switch?
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673
if you smash your Td5, the inertia switch would kill the engine. You could only restart after you reset that switch. IIRC? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Same thing that senses an impact and sets off airbags (in any other vehicle that is!). Treat every day as if it is your last....one day you will be right!! |
ah, cool. funny thing with the anti-stall you'd think they'd have had an inertia switch fitted. when my clutch packed up i had a scary time trying to stop the beast!, had to turn off the ignition (fortunately before i hit the wall - might have pushed the wall over!). www.ralton.co.za
I misunderstood - it measures rapidly decreasing speed. It's not a manual switch (like the kill button on a motorcycle) to stop the engine.
Ignore my previous post... www.ralton.co.za |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205
The switch on the Td5's has a small ball beearing inside it (if you take one off and shake it, you can hear it rattle around), like was said, a rapid deceleration (and maybe a "thump" at the end of it) will cause said ballbearing to jump out of its socket and kill the ECU & engine.
It's obviously well designed, as general off road use never seems to trigger it. Just looked through microcat, and indeed, there isn't one listed for puma's. |
| bartv Member Since: 03 Oct 2010 Location: Belgium Posts: 12 |
Is there another system (instead of the inertia) that will cut the fuel after a crash?
And does it only cut the fuel or does it more? My roll-ver defender is not getting any fuel, but it does start when I give it fuel straight to the engine. |
| Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228
Bart,
Did you check if the fuel pump is doing what it's supposed to do |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
Is it a Puma or Td5? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Puma
