Home > Puma (Tdci) > Transfer case (WTH)
MK
Transfer case (WTH)
Today at the dealer complaining as I always do.
Anyway, the chief mechanic sweared by his mother that the LT230Q transfer case is 40%front-60%rear and 50/50 only when locked, etc and therefore there is always a clonk to compensate 2/3 ratio.
Is he right? Shocked Puma 110" SW
Post #32573 19th May 2010 9:25pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
as far as im aware it drives the wheel with the least amount of friction if you jack your vehicle up and put it into gear the drive will got to only that wheel put it in difflock and it will to one front wheel and one back wheel
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #32577 19th May 2010 9:30pm
mse
Rubbish - but it explains why we get what we do with LR mechanics.
Search for AndrewS post on diffs or similar and the diagrams will confirm how it works Mike
Post #32589 19th May 2010 10:38pm
K9F
This one????
http://www.defender2.net/forum/topic2427.html?highlight=diffs If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32590 19th May 2010 10:43pm
mse
Post #32594 19th May 2010 10:50pm
dgardel
Italy
Sorry for your Dealer but...............
inside the tranfer box there is a "normal" diff. so when you drive (no curves) the torque is 50%-50% no way!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32617 20th May 2010 8:30am
Eduardo
Well,
I receive the same aswer sone time ago from the same dealer, but I didnt give me the time to explain him with apples why this cannot be possible with a central diff (locked or unlocked). There is no way if you are not turning that you can have different force in each axis without have different speed also.
This is our main problem in Chile, a dealer that knows nothing about what they are servicing, and the worst thing is that is the only one Big Cry Big Cry
Cheers Eduardo
Post #32639 20th May 2010 2:15pm
MK
Ok, but still there is a chance that the TCase has torque biased diff, which I doubt, because AFAIK those diffs are Torsen type.
For me the only way to check it is by lifting the rig and see that crossed wheels (or both props) do one turn at the time. is it? Confused
Apparently he will show me a LR tech report or so written by a LR engineer Shocked Puma 110" SW
Post #32640 20th May 2010 2:23pm
dgardel
Italy
NORMAL DIFF................. Thumbs Up
no limited slip clutches, no torsen gears or others toys....
only a very good 100% mechanic locking system (probably the best for off-roader transfer box....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32642 20th May 2010 2:44pm
The puma uses the same center differential as the Td5's, TBB500060 (just checked on microcat), which is a plain, open, non torque sensing differential.
Your mechanic is talking BS.... i'd not let him anywhere near my truck!!!!
Post #32714 21st May 2010 7:32am
Naks
Indeed! Shocked
Post #32719 21st May 2010 9:22am
MK
He did it again!
I`m not going to write what he said last night when I collected the rig, but next time (monday) I`m going with a chap who has been on the 4x4 bussines for 40 years. I�ll bury the guy on his own Censored Evil or Very Mad Puma 110" SW
Post #32728 21st May 2010 1:53pm
MK
1 dealer-1MK
Today I went to my mechanic and checked on the front double cardon (CV joint) as it was blamed to be the cause of my clunk. Before, we lifted the car and made it run with all wheels on the air. Guess what! Indeed front wheels spinned faster than rear ones. With difflock on, front and rear turned at same speed Shocked
Anyway we took the front prop off and all joints were perfect. So drove to visit the dealer to show him the prop and joints...........he said today he coul not find anything wrong with the parts Twisted Evil
Dealer noticed excess slack on the transfer so they will change it (this has about 10kkm of wear). Finally he said most probable cause of failure is due to the higher mass of the front prop stressing the gears in the TC. sounds also like a pile of BS.
MK Puma 110" SW
Post #32879 24th May 2010 9:40pm
harveyg77
MK wrote:
1 dealer-1MK
...we lifted the car and made it run with all wheels on the air. Guess what! Indeed front wheels spinned faster than rear ones. With difflock on, front and rear turned at same speed...
MK
Its an open differential so will send more power to the side with least resistance. The rear prop' is longer and heavier, therefore offers greater resistance than the shorter, lighter front prop'. This would account for the front wheels turning faster than the rears - they were getting fractionally more power.
Edited to removed typos.
Post #32893 25th May 2010 7:52am
dgardel
Italy
I agree with and confirm harveyg77 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32904 25th May 2010 9:35am
