Home > Maintenance & Modifications > Defender 110 flat bed
rory_mcw
Morning,
I have bought a 2003 110 hi cap to modify to carry my argocat on the back.
Does anyone have any photos of their 110 flat bed defenders?
Post #328931 7th May 2014 11:14am
rory_mcw
This is what I want to carry
Around 600kg
Post #328957 7th May 2014 12:49pm
jimbob7
Quite a bit of weight that will be very high up,I'd buy a trailer. Pov.spec,ftw. 2006, 110,TD5.
Post #328964 7th May 2014 1:08pm
rory_mcw
i have got plenty of trailers, im just wanting to carry a machine without a trailer.
Post #328967 7th May 2014 1:22pm
Surrey Rover
I am not sure mine qualifies as a flat bed as it’s a tipper, but I believe the bed is at the same height and of course the sides come off. Happy to take some pictures for you if it helps.
Something to bear in mind though, clearly the weight isn’t going to be an issue but as Jimbob states, that's a lot of weight that high up. I use mine for carrying logs and without modification if felt like i was going to tip over around most sweeping bends. Now mine runs with different wheel’s/tyres and i’ve got airbag helpers, it's made a massive difference and I’m happy to load it to the gunwales. Nick
2.2 110 Tipper
Post #328979 7th May 2014 2:06pm
Mountain_man
Wales
One of Land Rovers great qualities that make them so successful off road is the coil sprung rear axle with massive articulation compared to any leaf sprung trucks. However, this is also a major problem for what you propose since the height of your flat bed is going to be limited by the maximum articulation. Take a look at the top of the wheel arch boxes in the back of your truck. Your flat besd must be at least this high. As stated above this will make any load carried up there awfully unstable and it will also look gash I am afraid. Confused
Post #328983 7th May 2014 2:31pm
Mountain_man
Wales
Here is one that doesn't look too bad
http://www.aulro.com/afvb/projects-tutoria...0-ute.html
Post #328985 7th May 2014 2:36pm
rory_mcw
Thanks for the link.
To be honest im not fussed about how it looks.
It would be handy to be able to transport an argo without the need to tow a trailer.
Im going to give it a go and see how it comes out Cool .............. whats the worst that can happen. Laughing
Post #328993 7th May 2014 2:49pm
You need an Eezion Landrover - perfect solution but sadly nearly as rare as hens' teeth.
Post #329007 7th May 2014 3:19pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
That's awesome Bow down
I love those Aussie style traybacks. That's the way to go. He who dies with the most toys...wins!
Post #329011 7th May 2014 3:22pm
Likeomg
id look for a 130...
Post #329026 7th May 2014 3:41pm
Can't be any worse than a 110/130 with a cherry picker or lazy sides on (or as I saw in town today, a 110 with a grit spreader on the back)
Fit the 130" double spring inserts (i have these on my 110) and it stops a lot of wallowing.
Post #329030 7th May 2014 3:44pm
Had to look that one up:
Maybe he'd get away with this:
Post #329079 7th May 2014 6:09pm
I thought it might send a few people off to Google!
Here's an 80"-based Eezion:
Post #329120 7th May 2014 8:19pm
rory_mcw
Picked it up today.
Doesn't look too bad.
Post #331898 18th May 2014 9:49pm
