![]() | Home > Td5 > Swivel Housing kit |
| Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240
So I spoke to Barry4x4 (<<Great people) super helpful.
And they have come up with the following parts list. It is more expensive than britpart but I think it will be worth it. Here is the list of things if anyone else needs it. Part Number Qty Description TAR100050 Gen 1 Swivel Pin Kit Upper ABS Genuine 606666G 1 Swivel Bearing Lower NTN FTC5366 1 Swivel Ball Housing Allmakes FTC3401 1 Ball Seal FRC4206 1 Ball Seal Retainer Gasket FTC4785 1 Hub Seal 1 Flange Gasket 1 Hub Nut 1 Stub Gasekt 1 Swivel Ball Gasket 1 Swivel Grease Sachet Defender 90 XS TD5 (03 Reg) |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Why not go genuine?
Because it costs a fortune
As usual my student budget doesn't stretch that far |
| Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35
I recently did my swivel balls using a Britpart swivel kit and OEM seals and bearings.
LRDirect list the britpart balls as OEM, but beware the Britpart swivel kit has a lower price than the Britpart OEM swivel ball on its own. Wish I had seen that earlier While you are there also replace the stub axle bearing (FTC861), seal (FTC840 for ABS or FTC5268 nonABS) and thrust washer (FTC56). Also condider replacing the hub bearings (STC4382), at least regrease them. To do that you will need a new inner hub seal (FTC4785). Don't forget that you need a 12-point socket to loosen the brake caliper and a ratchet spanner will save you lots of time removing the swivel balls from the axle. Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
Both of mine are Britpart - been at least 5 years for one of them and no issues yet.
Naturally the seals and bearings were bought separately, decent makes (Timken etc) |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Collating what has been said above gives a parts list of these:
TAR100050 Gen 1 Swivel Pin Kit Upper ABS Genuine 606666 1 Swivel Bearing Lower 2 needed per side FTC5366 1 Swivel Ball Housing FTC3401 1 Ball Seal FRC4206 1 Ball Seal Retainer Gasket FTC4785 1 Hub Seal 571752 Flange Gasket RFD10000 Hub Nut FTC 3650 Stub Gasket FTC 3646 Swivel Ball Gasket FTC 3435 Swivel Grease Sachet FTC861 axle bearing, FTC 5268 stub axle seal for ABS FTC 56 thrust washer. The stub axle seal has been updated to the latest version. Land Rover main dealer parts quoted £650.82 for both sides. including VAT. Is a 12-point socket different to the ordinary type or special? Can anyone advise if any other parts are needed before the job starts, just don't want the car off the road because of a missing part. Merlin |
