Home > Td5 > Swivel Housing kit
Waldo
Swivel Housing kit
Does anyone know where I can source a swivel housing kit for my ABS defender
THAT ISN'T BRITPART
I've been through all the suppliers websites I can think of and only britpart appears. Big Cry
Thanks in advance
Will Defender 90 XS TD5 (03 Reg)
Post #327460 1st May 2014 8:42am
Waldo
So I spoke to Barry4x4 (<<Great people) super helpful.
And they have come up with the following parts list. It is more expensive than britpart but I think it will be worth it.
Here is the list of things if anyone else needs it.
Part Number Qty Description
TAR100050 Gen 1 Swivel Pin Kit Upper ABS Genuine
606666G 1 Swivel Bearing Lower NTN
FTC5366 1 Swivel Ball Housing Allmakes
FTC3401 1 Ball Seal
FRC4206 1 Ball Seal Retainer Gasket
FTC4785 1 Hub Seal
1 Flange Gasket
1 Hub Nut
1 Stub Gasekt
1 Swivel Ball Gasket
1 Swivel Grease Sachet Defender 90 XS TD5 (03 Reg)
Post #327907 2nd May 2014 8:38pm
shaggydog
Why not go genuine?
Post #327946 2nd May 2014 10:42pm
Waldo
Because it costs a fortune Big Cry
As usual my student budget doesn't stretch that far Rolling Eyes Defender 90 XS TD5 (03 Reg)
Post #327996 3rd May 2014 11:43am
Grey110
Netherlands
I recently did my swivel balls using a Britpart swivel kit and OEM seals and bearings.
LRDirect list the britpart balls as OEM, but beware the Britpart swivel kit has a lower price than the Britpart OEM swivel ball on its own. Wish I had seen that earlier Embarassed
While you are there also replace the stub axle bearing (FTC861), seal (FTC840 for ABS or FTC5268 nonABS) and thrust washer (FTC56).
Also condider replacing the hub bearings (STC4382), at least regrease them. To do that you will need a new inner hub seal (FTC4785).
Don't forget that you need a 12-point socket to loosen the brake caliper and a ratchet spanner will save you lots of time removing the swivel balls from the axle. Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #328251 4th May 2014 11:23am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Both of mine are Britpart - been at least 5 years for one of them and no issues yet.
Naturally the seals and bearings were bought separately, decent makes (Timken etc)
Post #329439 8th May 2014 9:18pm
Merlin
Collating what has been said above gives a parts list of these:
606666 1 Swivel Bearing Lower 2 needed per side
FTC3401 1 Ball Seal
FTC4785 1 Hub Seal
571752 Flange Gasket
RFD10000 Hub Nut
FTC 3650 Stub Gasket
FTC 3646 Swivel Ball Gasket
FTC 3435 Swivel Grease Sachet
FTC861 axle bearing,
FTC 5268 stub axle seal for ABS
FTC 56 thrust washer.
The stub axle seal has been updated to the latest version.
Land Rover main dealer parts quoted £650.82 for both sides. including VAT.
Is a 12-point socket different to the ordinary type or special?
Can anyone advise if any other parts are needed before the job starts, just don't want the car off the road because of a missing part.
Merlin
Post #357063 10th Sep 2014 5:36pm
