Home > Puma (Tdci) > I've joined Puma problems posse - power steering fluid leak
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Just came home from a short drive ( 2 hrs) and noticed that my defender was leaking something onto the drive.
Sad
It turns out it is power steering fluid - hose connecting to union has been tightened so leak stopped but still weeps when under pressure.
Its off to the dealer but hope they can get it fixed soon as big plans for bank holiday weekend.
aaargh!!!
Post #32781 22nd May 2010 8:59pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
good luck, mine is leaking like a good un and dealer says the boxes are on back order, don't know when they will be in, and after all it is only the steering....
Post #32797 23rd May 2010 7:48am
alwoodley72 wrote:
good luck, mine is leaking like a good un and dealer says the boxes are on back order, don't know when they will be in, and after all it is only the ....
STEERING no not important at all Laughing
Post #32809 23rd May 2010 6:02pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
steering Box
Hi,
Just had mine done - took 2 weeks on back order. Now fitted and all's well!
Joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #32856 24th May 2010 4:27pm
Eduardo
Same as me...
Waiting for the famous steering box. Fortunately the leaking is just one or two drop in the parking place every day. Eduardo
Post #32860 24th May 2010 4:49pm
kmac
Had Land Rover assist check it out this morning. He has tightened the nut and all leaking has stopped even under pressure. Lets hope it holds. There should be a fingers crossed emoticon
Post #32876 24th May 2010 8:05pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
im waiting for a new pump box for mine only 4 weeks so far they wernt going to do it at first because of my big tyres
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #32935 25th May 2010 4:46pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You only need to tighten the nut to reattach the hose. Mine did it 2 years ago. LR assist fixed it on the drive. Not had a problem since.
You shouldn't need to wait for any parts - they've not changed the design at all. Best to just get your existing hoses tightened. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #32980 26th May 2010 8:33am
SJM
Mine did the same. Again, LR Assist were with me in under an hour, tightened it all up and not had a problem since. Mind you, left some nasty stains on my driveway which despite plenty of effort to remove them are still showing. Mad
Post #33212 29th May 2010 12:53pm
big steve
mine isnt loose hoses its the actual steering box thats leaking?? 2015 2.2 tdci hardtop xs
Post #33243 30th May 2010 6:33am
spudfan
Ireland
Could very well be the steering box. You will see a drip from the front lower lip. It is actually coming from the top seal on the box and travelling down. Do not be too concerned unless you are topping up the reservoir. I noticed mine a little damp on top with a little drip from the front lower lip. Goes in next week for a steering box and a clutch. Actually I have no bother with the clutch apart from a rattle when turning her off. It disappears if I turn her off with the clutch pedal depressed. Seems to be the clutch springs so I pointed it out to the dealer and they ordered a replacement. Changes gear and drives beautifully so I was tempted to leave well enough alone. Decided I might as well get it done under the warranty. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #33271 30th May 2010 9:49am
