![]() | Home > Puma (Tdci) > I've joined Puma problems posse - power steering fluid leak |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
good luck, mine is leaking like a good un and dealer says the boxes are on back order, don't know when they will be in, and after all it is only the steering....
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
STEERING no not important at all ![]() |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi,
Just had mine done - took 2 weeks on back order. Now fitted and all's well! Joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Same as me...
Waiting for the famous steering box. Fortunately the leaking is just one or two drop in the parking place every day. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Had Land Rover assist check it out this morning. He has tightened the nut and all leaking has stopped even under pressure. Lets hope it holds. There should be a fingers crossed emoticon
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
im waiting for a new pump box for mine only 4 weeks so far they wernt going to do it at first because of my big tyres
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
You only need to tighten the nut to reattach the hose. Mine did it 2 years ago. LR assist fixed it on the drive. Not had a problem since.
You shouldn't need to wait for any parts - they've not changed the design at all. Best to just get your existing hoses tightened. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Mine did the same. Again, LR Assist were with me in under an hour, tightened it all up and not had a problem since. Mind you, left some nasty stains on my driveway which despite plenty of effort to remove them are still showing.
mine isnt loose hoses its the actual steering box thats leaking?? 2015 2.2 tdci hardtop xs
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Could very well be the steering box. You will see a drip from the front lower lip. It is actually coming from the top seal on the box and travelling down. Do not be too concerned unless you are topping up the reservoir. I noticed mine a little damp on top with a little drip from the front lower lip. Goes in next week for a steering box and a clutch. Actually I have no bother with the clutch apart from a rattle when turning her off. It disappears if I turn her off with the clutch pedal depressed. Seems to be the clutch springs so I pointed it out to the dealer and they ordered a replacement. Changes gear and drives beautifully so I was tempted to leave well enough alone. Decided I might as well get it done under the warranty. 1982 88" 2.25 diesel
