Home > Maintenance & Modifications > Puma 2.4 Diff Oil & Drain plugs
DavidBMB
Hi, I'm new to this forum and have just picked up a used 2010 puma 2.4 Defender. I would like to change the diff oil but wondered if someone could answer a few questions for me.
1) What socket will I need to remove the drain plugs / fill ? The front one looks awkward to get at!
2) Do I need to use a sealant when refitting the plugs?
3) What torque setting should I tighten up to?
And finally what oils do people recommend for the diff and gearbox?
Sorry if the questions are a bit obvious, but it's been years since I had a car I could have a go at servicing myself!
Thanks in advance.
David
Post #327454 1st May 2014 7:59am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
hi welcome to the forum
1/2 inch ratchet does the job
no you dont need sealent as there on a taper
i dont torque them up but just give them a good turn so there F/T
gearbox oil shouldnt need to be changed on a puma really but its personel preference i spose Thumbs Up
i know proper oil for the gearbox is about £23 a litre
hope you enjoy the new ownership 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #327459 1st May 2014 8:41am
MartinK
This linky may help Smile
http://www.defender2.net/forum/topic8707.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #327482 1st May 2014 10:09am
DavidBMB
Thanks all for the advice. That's part of my weekend sorted.
I'm enjoying the truck despite all it's flaws it's got character which not much does these days!
Post #327617 1st May 2014 8:29pm
DavidBMB
A supplementary question... I keep reading that the early Puma clutch was replaced. Any idea when this was. Would my 2010 have the new design?
Post #327618 1st May 2014 8:33pm
There have now been at least 4 versions of the Puma clutch driven plate, they are getting better but are still not great. A 2010 vehicle will probably have the current version, but when it needs replacing it will be because the springs are failing not because it's worn out. It should be good for 50k miles at least, but once the "death rattle" starts and the gearchange becomes snatchy then fit a new one.
Sadly LR forgot how to design a decent clutch after the 300Tdi and both Td5 and Tdci are pretty hopeless. At least the Puma doesn't have a DMF, so the clutch is relatively cheap.
Post #327669 1st May 2014 10:39pm
smb
Hi David,
Welcome to the Forum.
As Blackwolf has said, there are a number of versions. Mine is a 2010(2011my) and started the rattle at about 25k. I carried with the rattle getting worse and at 60k heavy vibrations started through the drive train and by 65k I thought it was about time I got a new clutch. Got the AP clutch pack from LRS and it completely changed the quality of drive. Far better than the early days of the old one.
However, the clutch that came out had FORD stamped all over it. It was only half worn which is pretty good for 65k with lots of towing, but all the springs were completely shot at with a number of retaining lugs worn to nothing. I probably could have got another 30k out of it, but it was the vibration(similar to off balance wheels) that got too much to cope with.
Speak to Derek at LRS and ask him for the best current clutch pack and I am sure he will advise right. He always does me a good deal and excellent service.
Post #327693 1st May 2014 11:19pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Going further off topic but -- are these two vids good examples of the clutch rattle? Can hear what sounds like a sustained, quick hard rattle laid over the engine noise, completely unlike the EGR chunka-chunka, which is quite slow.
 2009 110 XS Station Wagon
Post #327707 2nd May 2014 2:37am
The easiest way tyo check for worn springs in the driven plate is to switch the engine off in neutral with the clutch in (ie pedal up, foot off clutch) and listen for a brief unmistakable rattle as the driven plate hub and gearbox mainshaft rattles back and forth against the clutch springs. Compare the sound to switching off the engine with your foot on the clutch (ie clutch out).
With a good clutch there should be virtually no differenc in sound. With a dying clutch it will be unmistakable.
If you do have a rattly clutch, be prepared to be delighted with the improvement in drive quality when you get it renewed. Because the deterioration is gradual and progressive you tend not really to be aware of it getting worse. The improvement is sudden and huge, and will put a smile on your face.
Post #327748 2nd May 2014 9:20am
DavidBMB
Again., thank you all for the advice. I think my clutch is ok at the moment. Well, by that I mean there is no significant rattle. Changing from first to second can sometimes be a little clunky even with a v slow gear change but I think that's usual with a defender !
Post #327757 2nd May 2014 9:48am
timbar
Yeah, needs to be slow and you need to feel what the engine's doing.
@blackwolf -- thanks Thumbs Up 2009 110 XS Station Wagon
Post #327825 2nd May 2014 1:21pm
