Home > Technical > Footwell a tad damp! Bear with me!
Page 2 of 2 <12
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
This was a bit of it:
Post #327200 30th Apr 2014 11:48am
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I think part of the problem is the fact the closure isn't in the centre of the flap so the one end isn't being pulled in as tight as the side where the arm is.
Ive changed the seal and gonna see how this goes.
Post #327206 30th Apr 2014 12:13pm
X4SKP
Hello Buz
You are probably pursuing the right fix here, but is worth checking the windscreen seal.
I wasted a few hours once convinced it was the NS vent but a split seal below the tax
disc was the route in, two weeks later a cracked windscreen forced an overall fix.
I needed to source the seal independently to the windscreen fitter to get a result.
A power wash test proved all was then ok.
...just a thought. SKIP
Post #327239 30th Apr 2014 2:55pm
Buz
Thanks Skip, I think you could well be right. The screen rubber is split and perished, not sure how to get this replaced at the moment. Never messed with replacing windows.
The joys of defender ownership Laughing
Post #327390 30th Apr 2014 9:43pm
X4SKP
Hello Buz
Idea Try and get some silicon into the current seal, to then see if this is the cause.
It might be only part of the problem, or not the problem, or with luck the problem Exclamation
As you say the joys of Defender ownership. Buy a Defender... Become a Detective.
I used these guys for the seal...
http://www.rimmerbros.co.uk/Item--i-GRID010589 SKIP
Post #327549 1st May 2014 4:23pm
Buz
Skip, you bu66er, after looking at that link i'm now debating changing the screen for a heated one Thud
Post #327596 1st May 2014 7:30pm
Buz
OK, getting there slowly.
Water still coming in, i ran water on the passenger door corner where it meets the bulkhead, up to just above the top door hinge. Water is coming in somewhere and showing inside around the area of the door stay. I've put sealer around the top door hinge as thought it was there but doesn't seem to be.
Whats on the inner side of the wing that could be causing this leak?
Any other suggestions?
Post #334200 28th May 2014 7:07pm
excossack
Looking the previous pictures posted and the diagram above, if fitting the rubber seals, these fit on the bulkhead in the recess for the vent and you have seals on the flaps themselves? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #334216 28th May 2014 7:56pm
Buz
The old ones were stuck to the flaps, so I just replaced them. They don't leak anymore, i fabricated some brackets and they are pulled tight shut, 2 fixing points per flap, they won't leak as they won't open anymore.
This water seems to be coming in by the door pillar kind of area
Post #334218 28th May 2014 8:00pm
Page 2 of 2 <12
