Home > Maintenance & Modifications > Heavy duty track rod
Waldo
I'm after a heavy duty track rod for my Defender 90 (03 reg)
Any makes in particular to steer clear of or alternatively are the dogs Censored and I should definitely get.
Was thinking of getting standard to replace standard but for the minimal increase in price I'll go heavy duty.
Will Defender 90 XS TD5 (03 Reg)
Post #326968 29th Apr 2014 2:36pm
landy andy
Get sumo bars from Gwyn Lewis. Great kit simple. He also provides them with track rod ends that have grease nipples.
I've run them for years without issue, and will be changing the new truck ones across when needed.
Andy
Post #326986 29th Apr 2014 4:59pm
Alex1976
+1 for Gwyn Lewis Sumo Bars.
I have a set on my Defender 90 and also the Discovery drop arm conversion. Highly recommend them.
Post #327079 29th Apr 2014 9:39pm
Waldo
Ignore, see below Defender 90 XS TD5 (03 Reg)
Post #327182 30th Apr 2014 9:54am
Waldo
Thanks guys, did either of you get the kit which converted it from a standard defender "swan neck" drop arm to a "straight" discovery drop arm. Just wondering if it's worth getting??
Considering I'm not going to be doing any extreme off roading I should be fine with his standard heavy duty as well, no need to go for extreme?
Looks like some decent gear he's putting out. Defender 90 XS TD5 (03 Reg)
Post #327183 30th Apr 2014 9:57am
landy andy
I swapped drop arm to disco one, BUT getting the original drop arm off was a Censored . cut it off in the end. But if your drop arm ball joint is ok, leave alone.
Andy
Post #327185 30th Apr 2014 10:04am
Waldo
Okey dokey, thanks a lot
Do you have his extreme bars on andy, or standard ones?
Post #327186 30th Apr 2014 10:05am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I have a Paddocks heavy duty track rod which has served me very well. I have also done the Disco drop arm and my steering has never been better, I went the easy way and bought a steering box with arm attached and sold on my defender one for the same price. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #327187 30th Apr 2014 10:06am
landy andy
I had (they were on the 90) standard ones, I think, as I'm not sure he did extreme ones then. I think standard ones will be fine for you. Gwyn's extreme is very extreme for everyone else Whistle . Get loads of grease/copper slip in the tubes when assembling Thumbs Up Much better design than the standard clamp end.
Andy
Post #327188 30th Apr 2014 10:09am
Waldo
Many thanks guys, I'll get on to him later today.
Edit: It's all ordered, very helpful team they have
Post #327201 30th Apr 2014 11:52am
