![]() | Home > Maintenance & Modifications > Heavy duty track rod |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Get sumo bars from Gwyn Lewis. Great kit simple. He also provides them with track rod ends that have grease nipples.
I've run them for years without issue, and will be changing the new truck ones across when needed. Andy |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
+1 for Gwyn Lewis Sumo Bars.
I have a set on my Defender 90 and also the Discovery drop arm conversion. Highly recommend them. |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Ignore, see below Defender 90 XS TD5 (03 Reg)
Thanks guys, did either of you get the kit which converted it from a standard defender "swan neck" drop arm to a "straight" discovery drop arm. Just wondering if it's worth getting??
Considering I'm not going to be doing any extreme off roading I should be fine with his standard heavy duty as well, no need to go for extreme? Looks like some decent gear he's putting out. Defender 90 XS TD5 (03 Reg) |
I swapped drop arm to disco one, BUT getting the original drop arm off was a
![]() Andy |
Okey dokey, thanks a lot
Do you have his extreme bars on andy, or standard ones? Will Defender 90 XS TD5 (03 Reg) |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
I have a Paddocks heavy duty track rod which has served me very well. I have also done the Disco drop arm and my steering has never been better, I went the easy way and bought a steering box with arm attached and sold on my defender one for the same price. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
I had (they were on the 90) standard ones, I think, as I'm not sure he did extreme ones then. I think standard ones will be fine for you. Gwyn's extreme is very extreme for everyone else
![]() ![]() Andy |
Many thanks guys, I'll get on to him later today.
Edit: It's all ordered, very helpful team they have Will Defender 90 XS TD5 (03 Reg) |
