Home > Wheels & Tyres > BFG KM2 tyre size on standard truck
tony110dc
United Kingdom 2004 Defender 110 Td5 USW Corris Grey
Hi all,
This is my first post!
I currently have Cooper STT 265/75/16 tyres, im changing to BFG KM2's
My truck has standard height suspension (its HD with fox shocks) do you think i could go up a size to 285/75/16??
Post #326621 28th Apr 2014 11:07am
I have, with no problems whatsoever (285/75 x 16 BFG MK2 Muds on Boosts).
You will find it advantageous to fit 30mm spacers to improve the turning circle, and the outside of the vehicle will get covered in crud, but it works fine.
Many here will tell you it can't/shouldn't/mustn't be done, and it is true that a Boost is narrower than the manufacturer's recommended minimum width for a 285, but it fits fine. Mine have done over 100k miles with no dramas at all.
Post #326630 28th Apr 2014 11:56am
tony110dc
Thanks for that, I'm going to order 6 today, they are going on 7"X16" Blindo Alloys, was toying with the idea of 30mm spacers, any particular make you could recomend?
Post #326633 28th Apr 2014 12:15pm
I used Rakeway spacers, since I think they are the best. There are many available nowadays of rather indistinct origins, so I would always specifically choose a good branded product direct from source. They're also pretty good value.
If you're buying the Blindos I think that you can get an offset equivalent to a Boost on 30mm anyway, in which case you may not need spacers at all.
PS - Why 6, not the more predictable 5?
Post #326679 28th Apr 2014 3:04pm
tony110dc
Yeah i think my blindo's have the off-set already, Ive do a bit overland, so one spare on the back & one on the roof (just when im on a trip)
Post #326684 28th Apr 2014 3:18pm
SailingTom
Tony ive just put 285's on evo course dakars (like blindo with the same offset) and had spacers fitted allready. Im about to take the spacers off as there offset allready. Thought i'd post as might save you a bit of money on spacers. Thumbs Up Heres a pic of them with 30mm spacer to help you decide, there just under the arches but would flick everything up the sides.
 Defender puma dormobile camper
Post #326846 28th Apr 2014 10:26pm
BigWheels
I have 255/85s Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #326867 28th Apr 2014 11:15pm
g-mack
255/85s would and will be my next choice! My 109 thread
my youtube channel
Post #326887 29th Apr 2014 12:06am
