![]() | Home > Maintenance & Modifications > Snapped Dipstick |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Hi there
have you tried a search as i'm sure this came up a while ago im not good at this computer lark or id find and post it for you steve e |
search under broken dipstick
GSD Member Since: 18 Dec 2012 Location: UK Posts: 38 ![]() |
Cheers Steve. I tried a 'Google' but nothing came up for this site, Ill try a search.
Cheers |
Yep, found the 2 threads Steve, will go and drain the oil now.
![]() Thanks |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
Well, i've drained the oil in the hope it would be stuck to the magnetic sump plug. My sump plug, is definitely NOT magnetic, and there was nothing in the oil.
![]() Looked all over the engine bay but no sign of the tip. Sadly ive not the tools to take the sump off, thoroughly ![]() |
Did you run something down the tube to ensure it wasn't stuck in there? Chances are it'll be stuck in the sump and the oil flow wasn't strong enough to shift it.
Three choices really..... Invest or borrow the tooling to do the job below.... Phone a friend.... Or..... Arrange for a dealer/independant to collect and get them to sort it. The latter of course will cost you significantly more than the tools to do it. UK is a big place. Post whereabouts you are and a fellow forum member may offer to assist? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks K9F.
Im in the Catterick area, it was more I dont have any sealant to refit the sump. A truck mechanic over the road said 'not to worry, see's it on trucks alot'. If it was a work vehicle I wouldn't be too worried, but its my pride and joy and my cash. If I had a second car or I was in a city I could take the sump off slow time, but its our daily drive. I was surprised the sump plug isn't magnetic though. Think I'll replace that. |
if your bit of broken dipstick is still in the sump
Don't know what your engine is but maybe worth a try One way to remove is find a strong magnet and stick it to bottom of sump then slide magnet towards sump plug hole and if your lucky it would drag the part close to the hole then with a bit of mucking about you may get the bit out could also work if its a ally sump ,but you will have to hold it up to the sump |
Thanks Munch90, just ordered a strong magnet and will give it a bash.
K9F, i can put the remainder of the dipstick down with no resistance, so if it did stay in it went down the tube to the sump. Had a drive today and will drain the oil again, see if it turns up. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
You could always also get a magnetised old screwdriver. Or magnetise one, bend it almost to 90degrees and use that to fish about through the drain plug.
Hi Steve,
Just been doing that tonight, i also pushed a metal rod down the tube to push it into the sump. To be safe, the sump is coming off and I'll do a complete oil/filter change while I'm there. I've still got the feeling the bloody thing is hiding in the engine bay, or fell out on the road. Called round a few garages before I drove to ask if it was a danger to the engine, all seemed to say it 'shouldn't' do any damage. Excuse to buy more tools and get under the wagon though. Next investment is some ramps ![]() |
Update: Sump off today and the offending part was in the sump, in one piece. There is gauze fitted to the pipe/pump intake so it seems it couldnt go any further.
New dipstick fitted, will be more careful in future. ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Glad your sorted DEFENDER 90 TDCI XS,
