Home > Puma (Tdci) > Coolant temperature
Page 2 of 2 <12
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I would be curious to hear about the water and cylinder head temperature you all read on yours...
On my MY2009 2.4 Puma, using the standard cWT gauge on the Scanguage and the xcode I detailed here for CHT reading:
http://www.defender2.net/forum/post151519.html#151519
I often witness cWT reaching 95° Celsius and CHT around 102° - 105° Celsius on dual carriageways (highest I've seen was 108°C last summer on a very hot day with a trailer)
Given that I'm not entirely sure of my CHT conversion formula and seeing no ill effect whatsoever (car is running like a charm, pulling hard and never experienced any power loss or anything), do these values sound (too) high or is it just fine?
Post #323467 13th Apr 2014 3:25pm
Eduardo
Well
Come back from the Indy and nothing strange were found in the sensors, no DTC or something outside the parameters during operation Sad
Only the high pressure pump show for a fraction of second a value lower than expected but nothing strange.
He take out some dirt in the radiator area that can be block the airflow but he his not convinced that is the cause of the failure.
According to him can be the viscous fan coupling that are not working properly (according to him have some play and appears to be a little bit lazy to blow. Also he suggest me to change the thermostat that can be also part of the problem.
Does any sense?
Cheers to all Eduardo
Post #323592 14th Apr 2014 3:28am
Eduardo
Bump.... Eduardo
Post #324002 15th Apr 2014 11:04pm
dgardel
Italy
double post Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #324026 16th Apr 2014 8:03am
dgardel
Italy
IID Pro MV License
Post #324027 16th Apr 2014 8:04am
dgardel
Italy
Some dirt in the radiator area that can be block the airflow and viscous fan coupling that are not working properly............
both can be the cause Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #324028 16th Apr 2014 8:06am
Mongolia
France
My indy said me the same thing about the visco coupling.
But, first, I will change my turbo because it is tired (wings and actuator) and that can explain some hight température.
Then, I will clean the radiator (inside) and change my visco coupling if necessary
Post #324031 16th Apr 2014 8:19am
Mine suffered from erratic running and power loss but with no DTCs which was cured by a new Volume Control Valve on the fuel pump.
Post #324039 16th Apr 2014 8:55am
Mongolia
France
and mine was suffering of erratic running and power loss with orer heating, specially on long ramps.
Post #324065 16th Apr 2014 12:39pm
bell-auto-services
The viscous fan as said above can become lazy when stood in traffic or at slow city speeds sometimes due to age. If the inlet temps lower fairly quickly when you start driving faster again I'd suspect the fan is the cause and not moving enough air when you are stood still.
I've seen some people put a second fan on the back face of the radiator that is switched on with a temp sensor located in the inlet pipe when the temps rise. Even though the fan is on the radiator side closest to the engine when it draws air in it draws it past the intercooler cooling the air more than if it was not switched on at all.
Also some aftermarket intercoolers and some cast end tank coolers can quickly get to a heat soak stage with high ambient temps especially when air passing over them is low and this also can cause high inlet temps when the car is stood ideling for long periods or in slow moving traffic. Allisport and my self have recently designed a new intercooler with a new core design and this was also thought about as part of the new design.
We are now using new "LIFT" louvred internal fin technologie in the core tubes which is very new to the intercooler scene. It's proved to be more efficient in cooling as well as increasing the charge speed through the cooler core resulting in a more perky throttle response.
Pete.
Post #324081 16th Apr 2014 2:57pm
Eduardo
Thanks guys!
As usual very heplful Thumbs Up Eduardo
Post #324088 16th Apr 2014 4:31pm
o4dn
I still wonder what the safe range is for both coolant and cylinder head temperatures, i.e. when does hot become too hot...
Does anyone know?
Post #324092 16th Apr 2014 5:21pm
Eduardo
Finally I bougth a new viscous coupling fan and a new thermostat.
We will see what happens.
Cheers and thatns again Eduardo
Post #325965 25th Apr 2014 11:02am
Page 2 of 2 <12
