![]() | Home > Technical > Scangauge2 Xgauge codes |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Some Xgauge codes that work on Defender Pumas.
New XGauge: Fuel Pressure (if no FPR, Fuel Pressure at Rail). TXD: 07E00123. RXF: 044105230000. RXD: 2810 MTH: 000100570000. New Xgauge display name: FPr. Measurement units: MPa. New XGauge: EGR Duty Cycle TXD: 07E022113C RXF: 04628511063C RXD: 3010 MTH: 03E87FFF0000 New XGauge display name: EGR Measurement: Percent: 0.0 %= closed/ 100%= Fully Open New XGauge: Cylinder Head Temperature (Not coolant temp at head) TXD: 07E0221624 RXF: 046205160624 RXD: 3010 MTH: 000200010000 New XGauge Display Name: CHT Measurement: Degrees Fahrenheit New XGauge: Fuel Pump Duty Cycle TXD; 07E0221672 RXF: 046205160672 RXD: 3008 MTH: eBay Item No. 006400800000 New XGauge Display Name: FP Measurement: Percent New XGauge: Fuel Level TXD: 07E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 New XGauge Display Name: FLV Measurement: Percent New XGauge: Horsepower TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 New XGauge Display Name: HPR Measurement: Diesel Gross/Brake. This is an approximation on what BHP the ECU thinks it is producing in relation to the user power demanded. New XGauge: Engine Run Time TXD: 07DF011F RXF: 0441051F0000 RXD: 2810 MTH: 0001003C0000 New XGauge Display Name: ERT Measurement: Minutes If I find more that work on the Puma I'll add them here. If you have any that work on the Puma then please add them to the list ![]() Last edited by Lorryman100 on 10th Aug 2011 3:00pm. Edited 2 times in total |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
Thank You Lorryman100, what are Your reading for Fuel Pressure and horsepower? I suspect that for Fuel pressure the reading unit of measure is PSI/100. For Horsepower with MTH:000A00240000 it reachs at max 50 than with MTH:000A00170000 it reachs at max more than 115. And what is EGR at idle? 100 means that EGR is completly closed I suspect. Any idea or suggestion? Ciao Vinicio https://google.com/+VinicioSelleri |
Vinicio, good points as I should have listed them, I have now edited the original post to show values ![]() ![]() The maximum fuel rail pressure for the Duratorq engine fitted to the Puma is 1600 Bar which is roughly 23206 PSI (1 Bar = 14.5 PSI) so PSI x100 seems a fair approximation remembering these values shown on the scangauge are historic (milliseconds) and approximate so shouldn't be taken for Gospel as to what the pressure is at any one time. MTH:000A00170000 is for Petrol engines and not Diesels. Also the BHP shown is what the ECU thinks it is giving out to the power requested (A Dyno machine capable of reading all 4 wheels is the only way to get an accurate BHP/Torque output reading) and should only be used as a guide. I have had it up to 145 BHP in 5th gear at 60mph climbing a hill towing 2 tonnes, though I'm very sceptical that it is anywhere near reliable as even though my Defender is remapped the average gains for a remap are only about 30BHP and 80ft/lbs of Torque unless you go for a bigger intercooler and Hybrid Turbo that is.... The % for the EGR is 0% for fully closed up to 100% for fully open. The only time you should see 100% is when you are accelerating and at shut down when the EGR goes through the self clean cycle (5x chukka chukkas). At tickover it will range from 10%-15% and at cruise anywhere between 15% and 30%. The readings on the gauge will show 0.0 when closed and 100 when fully open. I see the main reason for having this gauge, is to rule out any running issues you suspect may be down to the EGR as this will either validate or rule out the EGR as the problem. I have the Alive Tuning Atric remap fitted which shows the EGR at 0,0 the whole time the engine is running and the remap also cancels the self clean cycle. I replaced the remap with the original fuel file to check too see what readings I got yesterday so I could answer your post ![]() If you have anything else you would like me to check, let me know ![]() ![]() ![]() ![]()
Glad to hear it Karlos ![]() ![]() ![]() HTH Brian. |
Ciao Brian, thank You for Your answer. I just want to tell You what I'm reading on my ScangougeII: EGR: at idle 15 - costant speed 25-35 - accelerating 100. So I guess that 100 means fully closed (no gas recirculation). FPr: because the max value I read is 180, the unit may be MPa. At idle I read 30. In fact the maximum fuel rail pressure for the Duratorq engine fitted to the Puma is 1800 Bar (see pdf manual) and safety valve opens at 2000 Bar. Waiting for Your reading. Ciao Vinicio https://google.com/+VinicioSelleri |
Vinicio,
If the EGR reads 100% this means the EGR is fully open ![]() These show the live data recorded on the MSV2 of my remapped defender and you can see from the 3 pictures that the EGR remains closed throughout the rev range showing a 0% reading. The scangauge x gauge also showed the same 0%. The valve is only ever open 100% when accelerating or when the self clean cycle works on the original OEM fuel file, I have tested it on both the original and remap version when I helped Gary at Alive with testing of the No EGR upgrade. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I will have to re install the original fuel file to get the readings you are after to compare once I get my Defender back from the missus. As to the fuel rail pressure, it is controlled to the optimum level working pressure of 1600 BAR. The 2000 BAR you quoted is for the Pressure limiting valve which opens at 2000 BAR to stop damage occurring to the fuel system through excessive pressure and is a one shot affair as it needs replacing afterwards because the valve can no longer be guaranteed leak-free. It will also induce a DTC and the engine will go into limp mode, also the complete fuel rail will need to be replaced as the limiting valve is not a serviceable item. ![]() Click image to enlarge If you got the reading of 180 FPr and think it is in Megapascals instead of PSI then that would give a reading of 26106 PSI or 1799.94 Bar almost 200Bar over the optimum pressure setting. Is your Defender remapped or does it sound clattery? Have you had DTC P1169 at any time? From memory I have not had that high a reading from mine the highest I have seen is 149 which is about 21610 PSI if it were 149 Megapascals. Though 149 x100 in PSI is only 14900 PSI. So I think you are spot on with the measurement being in MPa for FPr instead of PSIx100 ![]() ![]() HTH Brian. |
Hi Brian, my Defender is not remapped but I have racechip installed. I will check again FPr at idle, but maybe I reach 180 for the gain that racechip give to the signal coming from ECU. I had P1169 with engine in limp mode once I set the gain of racechip too high, but I reset DTC with scangougeII. Regarding EGR, You can be sure, when You push hard on throttle pedal EGR has to be closed because engine need fresh air!!! So I guess that 100 means completly closed. On the other hand at idle EGR has to be open. Ciao Vinicio https://google.com/+VinicioSelleri |
So what you are saying is that BBS/Nanocom/Scangauge have got their gauges back to front? As the earlier posts pictures of the MSV2's live data show the EGR at 0%, which means you are saying, it is fully open all of the time? Strange as my Defender runs like a little sweetie, which is weird as it should be running like a bag of spanners because from what you are saying, the EGR is open all the time at 0% and closed at 100% ![]() ![]() |
No Brian, I say that only scangougeII reading seems to be like that: 0 = fully open and 100 = fully closed. Please could You verify with scangouge? Regarding FPr, this is reading at idle: ![]() Click image to enlarge and this is at max FPr: ![]() Click image to enlarge Ciao Vinicio https://google.com/+VinicioSelleri |
I did verify it at post No 4 ![]() HTH Brian. |
I disconnected EGR cable and ScangougeII reading is 0. So, what kind of working cycle does have EGR valve on Defender? Because: 1. If I push hard on throttle I read 100 2. If I give very little throttle under 1500 rpm I read 100 3. At Idle I read 25-35 4. At costant speed over 2000 rpm I read over 35 5. At Idle if I do work the anti-stall system I read 100 Ciao Vinicio https://google.com/+VinicioSelleri |
log11 Member Since: 31 Mar 2009 Location: ATHENS Posts: 28 ![]() ![]() |
Hi,
Lorryman100 could you tell me how i can import the codes in my scangaugeII ??? Thank you |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 591 ![]() ![]() ![]() |
The actual unit used in X-Gauge reported values can be converted using the X-Gauge commands.
For example, being on the continent, I am a lot more used to Celsius than Fahrenheit but the X-Gauge command above reports CHT in Fahrenheit whereas I'd rather have it in Celsius instead (also because I already monitor water temp in Celsius so comparing values in different units is not practical). The given X-Gauge formula for CHT value is: Cylinder Head Temperature (Not coolant temp at head) TXD:07E0221624 RXF:046205160624 RXD:3010 MTH:000200010000 New X-Gauge Display Name: CHT Measurement: Degrees Fahrenheit According to the X-Gauge programming manual (http://www.scangauge.com/tips-and-tricks/xgauge-coding-manual-2/) MTH tells the ScanGaugeII how to scale and offset the data for the correct display. There are 3 fields in MTH. Multiplier Divider Add/Subtract 0000 0000 0000
So in the initial computation with MTH:000200010000 means (X * 2 / 1 + 0) which is basically X * 2 and that gives the result in Fahrenheit. According to Wikipedia (http://en.wikipedia.org/wiki/Farenheit), the formula to convert a value from Fahrenheit to Celsius is: (N - 32) * 5 / 9 but here N = X * 2, so to get the CHT in Celsius, the formula would become: (X * 2 - 32) * 5 / 9 which rounds up to X * 10 / 9 - 17.7 Which would translate in MTH fields as 000A0009FFEE 000A (<-Multiply by 10) 0009 (<-divide by 9) FFEE (< substract 18) The X-Gauge for CHT in Celsius is therefore: TXD:07E0221624 RXF:046205160624 RXD:3010 MTH:000A0009FFEE New X-Gauge Display Name:CHT Measurement: Degrees Celsius I tried it and the reading values seem sensible and in line with expectations (ie CHT is roughly a few degrees higher than the coolant temperature). |
