Home > Maintenance & Modifications > Front Shocks And Springs Puma
garryforrestuk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi can any one confirm that the procedure for removal of the shocks as in the sticky Front Shock Replacement by Martin K is exactly the same for 2014 model. As it looks like the inner wheel arch is one peace and you can not remove the turret through the engine bay. Any help please as to removal of shocks and springs.Garry
Post #320321 30th Mar 2014 8:04pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Just look in from the engine bay and see if the caps are screwed on Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #320397 30th Mar 2014 10:30pm
MartinK
I have to say, if I was doing it again, I wouldn't bother taking the old shocks out of the existing turrets, I would buy galavanized turrets and a stainless ring and nuts....then it's done for good...
Gwyn Lewis's galv turrets look good, and he also has turret ring kits... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #320434 31st Mar 2014 8:24am
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
I have followed the procedure on a 2014my, it was slightly easier because the fixing screw under the air box was not installed Thumbs Up
If you have air con the near side is a bit tricky to remove, carefully move the pipes to create room to remove the turret.
Lubricated the turrets with AC90 for added protection and re fitted, took a couple of hours to do both. Very happy with ride improvement. Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #320436 31st Mar 2014 8:35am
garryforrestuk
Hi thanks for all the help all sorted out, and the fixing screw under the air box was not installed also.Garry
Post #320651 31st Mar 2014 9:41pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I know what you mean about the inner wing, it sits on top of the turret slightly and makes the turret difficult to remove, I did it today. I did one side with the help of a second pair of hands above the shock/turret while I prized the inner wing inwards with a large screwdriver. The other side needed the turret ring to be changed anyway because one nut sheared, tbh it's probably easier to do it by taking the spring out, takes 10 mins rather than sweating and trying to force the turret in place.
Post #320683 31st Mar 2014 10:38pm
