![]() | Home > Puma (Tdci) > Warranty issue - Clutch problem not covered by warranty? |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
Think clutch is a well know problem and they changed the design?
Search the forum, lots threads on clutches... Disco 3 gone but the memory of the bills remain... XS 110 Utility maybe one day..... (did they fix the quality yet?) |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
I live in Dubai, which is in the middle east and Land Rover Middle East clearly states they do not cover the clutch but the clutch bearing should be covered I had mine replaced because one of the springs in the bearings came loose. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
If your bearing is on its way out you can tell by pressing the clutch peddle.... when the clutch is pressed does your transfer lever stop rattling ? if so then the bearing is on its way out......and also if your under warranty and the clutch is playing up get them to replace it ...I've had 3 replaced under warranty
Remember to your dealer this document LTB00166
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Mine has been changed by guarantee, but one of the springs of the plate fallen off.
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
Yes, there is indeed a known problem with the cluctch and they should replace it with the new spec clutch under warranty - they've replaced mine twice. www.ralton.co.za
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
sounds exacty like mine at 17000km and also when you start it it will give a rattle from the clutch dealer changed ASAP no questions ifs or buts, and so should your dealer |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
x 2 clutches under warenty on 30K km's
holmessato Member Since: 11 Mar 2010 Location: Milton Keynes Posts: 27 ![]() ![]() |
...mine is being replaced under warantee next week. Clutch rattle and transmission clunks are my problem
Guitarplayer Member Since: 09 Nov 2009 Location: Akersberga Posts: 18 ![]() ![]() ![]() |
Thank you all for the information.
I took the TSB-paper to the garage and this time they said that there was a well know problem and they have changed the design on the clutch and it will be on warranty ![]() They will change it the first week in june when they do the rest of the warranty work. Land Rover Defender 110 SX Station Wagon 2007 |
Got my Defender back after one week at the dealer mechanics
![]() Yes they did replace the clutch on Warranty, they also did more Warranty work: New heated windshield New CD-player New door sealings all around the vehicle New steering ball joint and some adjustments in the steeringbox Modified the air ventilation from the fuel tank New sealings lower side panels New Windshieldwiper motor and some brackets. They have also replaced the oil pan (new oil and filter included in the warranty work) New Brake vaccum pump They have also replaced the injectors earlier. My Defender is now running like a dream, when i turn the steering wheel the Defender now change direction ![]() ![]() ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4807 ![]() ![]() |
Indeed as it should be!
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5106 ![]() ![]() ![]() |
Quick question - why did you have the wiper motor replaced, the reason i ask is mine seems more noisy that the older ones but they say its fine Just a note on the steering box, unless the rule has changed in the last 6 months (been like it for 10 years) Your steering box shouldnt be adjusted in the warranty period by a dealer it should be exchanged How many clutch revisions are they on now, im aware of 3 (1 = original, 2 = modified, 3rd current further modification?) Mike |
mse:
I had 2 problems with the wipers, one was that the wipers didn't went back to its starting point when i turned off the switch, the other was that the wiper motor sounded like it was running very hard. Now it works perfect and the motor is quiet. I don't know exactly what they did with the steering box but they told me that they have done some overhaul and adjustments. I think the major problem was the ball joint, because now it has a really good respons when i turn the steering wheel. Land Rover Defender 110 SX Station Wagon 2007 |
