Home > Puma (Tdci) > This Puma is Getting Me down
CapeLandy
South Africa
Sad
My so called clutch problem was diagnosed incorrectly.
I found out the noise is still there in First Low at idle on a slight uphill/load up the driveway.
I was so p-off that I didn't have the energy to drive it back or even call them.
I did call the LR second hand dealer who offered only a fraction of the selling price so there goes that idea.
Maybe private sale. Big Cry
While I was testing I also noted a terrible drone from the rear when you take your foot off the gas in second gear at 2500 r/min.
Looks like I got a dud - definately going to sell her now.
It is more the dealer service that's forcing my hand. If they were able to sort or own up to the problems I would be a tiny bit more willing to hold out but they seem to be hoping to keep you going till 3 years is up.
Thought I would have a rant.
James Puma 110 - gone
Series III 1973 - going strong
Post #3167 11th Aug 2008 6:05pm
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
same old
still not had my one back went in on the 23.07.08 for a week to repair clutch and gearbox Rolling with laughter
Post #3169 11th Aug 2008 9:18pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Never give up - never surrender!
A few years ago when I was having a really trying time with my dealer over some stupidly insignificant warranty repairs they just couldn't seem to get right, I wrote to our national distributor (Land Rover Australia). Well you should have seen the action that resulted from that...
They promptly delivered a very nice loan car to me and took the Defender away to sort things out. Even then they didn't get it quite right so when they brought the vehicle back I simply sent them away again. Finally it was all sorted and I even got a couple of very subdued follow-up calls to see how it was all going. Land Rover used to have a "right first time" repairs clause in the warranty guide but I note that the wording is conveniently absent from the 07 model onwards. But it is still worth getting your national Land Rover corporation involved. They don't like the idea of customers being put off their product by poor dealer service. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #3171 12th Aug 2008 1:22am
mse
I think your right - dont give up, dont loose heart it will all come good.
Youll probably be needing a new diff and/or gear box (although it could always be something simple). Dealerships are funny things - some are dreadful and others are brilliant - on all cars, just that LR's are a little different and have people like us to complain.
I knew some one with a BMW M3 (well someone had to) and there were loads of problems, not least the dealership over filled the engine with oil and left it. Anyway the dealer were not good and they got BMW UK involved soon on, a different dealer was selected and BMWUK sorted it.
So be reassured, make a list and get back to them Mike
Post #3173 12th Aug 2008 3:03am
CapeLandy
South Africa
LR South Africa
I have now got a name and number of Technical guy at LR South Africa and I am going to find out if they are aware of the troubles that you guys in Aus and UK are finding which I assume is known by LR UK/Aus and whether they have replacement boxes and diffs with some sort of fix on the problem areas.
I will update tmrw once I make the call.
Post #3190 13th Aug 2008 5:06pm
CapeLandy
South Africa
LR South Africa
Spoke to a technical guy today at head office and he said straight that most gearbox issues have been loose clutch plates and springs and only a few complete gearbox failures where the gears stripped.
He tells me the boxes are bulletproof normally.
He said he would call my dealership and chat to them about the work they have already done and try and resolve the gearox and diff noises.
At least he admitted that there shouldn't be any strange noises and that I should not accept any excuses that "oh - they all make that noise", not that the dealer tried that one yet.
Lets wait and see, not holding my breath though. Puma 110 - gone
Post #3193 14th Aug 2008 9:08am
Daniel TD5
spoke to my dealer yesterday
new gear box fitted and clutch oil leak to cam cover fixed new front hub seals sorted now awaiting for a seal from some where for the driver side foot well water leak
gearbox seemed to be just a friday after noon jobbie failed early or not set up right when built
may get it back this week after four weeks Mr. Green
dan
Post #3194 14th Aug 2008 9:54am
CFB
Mine has been in and out of the dealer for the last few weeks, they still can't sort the issues out. After a long run, if I pull to a stop I get a loud chattering and jolting through the transmission which they put down to handbrake shoes not aligned etc. they have swapped them and the drum and also fitted some clips to the brake pads at the front as they thought this was the issue but it is still there and worse than ever. It was so bad yesterday that it was virtually undriveable in stop-stat traffic as it snatched and rattled and jolted me around Crying or Very sad
It is really Censored me off to be honest, i can accept faults occur but when they can't fix them and yet tell you specifically they have, it is infuriating. Andy
Post #3198 14th Aug 2008 3:59pm
CapeLandy
South Africa
Break Shoes
Have a look at the shoes, they definately only are supposed to be fitted in one direction and should have a nice leading edge on the lining material in one direction.
This was the problem on my Ser III years ago with the same symptoms.
Post #3199 14th Aug 2008 4:18pm
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
hi have a look at my post on this CFB http://www.defender2.net/forum/topic360.html
Dave
Post #3202 15th Aug 2008 4:09pm
CFB
That is definately the issue, will see what the dealer can do. Andy
Post #3206 15th Aug 2008 4:58pm
CapeLandy
South Africa
more news
I called the head office again and the guy told me they have ordered the modified clutch from the UK.
He is still sure that the clutch is at fault.
Lets hope so. Confused Puma 110 - gone
Post #3225 18th Aug 2008 9:47am
Daniel TD5
i hate to bring bad news but
i had a new clutch fitted in december 2007after about 6 month and six thousand miles. the dealer did mention
plates and springs 6 month later it was worst and it went in after a land rover uk manager came to the dealers and inspected it supected gearbox and clutch
so so far its been gone for
6 weeks due to abs failure and repaint
4 weeks due to clutch failure
this is the six week now dropped off 14.07.08
look on the bright side done over 10 k in loan cars so my defender as very low miles now Rolling with laughter
daniel
Post #3229 18th Aug 2008 10:41pm
CapeLandy
South Africa
Hi Daniel
Do they say what in the gearbox has given up or are they just fitting a new box?
I would love to know. The guys here are either denying gearbox issues or are pretty sure just the clutch is a problem.
I am amased that a clutch could have taken 4 weeks. Were they waiting so long for a new clutch plate Shocked
Post #3231 19th Aug 2008 6:24am
Daniel TD5
the way it works is
Dealer test drives then reports to land rover by email. they then allow strip down report what they find land rover again. land rover then allow replacecent parts dealer orders them and its seems part for the TDCi bits are taking a while to get
problem with my gear box was it was still in gear with the clutch depressed so was catching when i change
the way to tell was low box depress clutch put it into third and the car jumped forward with the clutch enganged ? gear box was still working just very poor gear change and very noisey clutch
Daniel
Post #3232 19th Aug 2008 8:17am
