Home > In Car Electronics > gps for ipad
Page 1 of 3 123>
landytom
gps for ipad
Anyone use a gps system for ipad??
Found this - http://www.ebay.co.uk/itm/GNS-2000-99-Kana...3a88a33576 - anyone had experience of this product??
Post #318673 24th Mar 2014 1:30pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Yep, I do. I got a copilot bluetooth GPS receiver for mine and it works great. I think it was around £20 from eBay.
I'm not sure if the Bluetooth stack on non-jailbroken iPads work with 3rd party devices though. I've jailbroken my iPad and downloaded a Bluetooth stack to do the job. I'm sure someone on here will know. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #318683 24th Mar 2014 2:02pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I downloaded co pilot for mine. If uses the internal GPS receiver and works very well.
Post #318686 24th Mar 2014 2:23pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Memory Map is a good one for off road as it can use Landranger OS maps. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #318706 24th Mar 2014 3:26pm
peterl
1987 Defender 90 300 Tdi HT Epsom Green
sorry to hijack the tread, I am looking for a gps system and it would be good to link it into the i pad, does the i pad need 3g and what options are best. Will mainly be used in France and Italy. (want to stay away from any mobile phone charges)
Any guidance would be good as I am in the dark on this one, but would rather use I pad as I have one and don't really want to buy a separate bit of kit unless it is necessary.
pete
Post #318711 24th Mar 2014 3:46pm
TheWarden
For GPS on a iPad you need the 3G model - but you don't need a SIM Card.
I have a iPad Mini mounted using a RAM Mount on a suction mount - has never fallen off.
I use Memory Map and have Tomtom for Wester Europe. 2013 Aintree Green 110 Station Wagon SX
Post #318728 24th Mar 2014 5:43pm
g-mack
dont think you do need 3g!! get one of these! http://bad-elf.com/pages/be-gps-1008-detail for real gps!!!! from satellites. using 3g masts for gps means once your out of range you lose your gps!! My 109 thread
my youtube channel
Post #318730 24th Mar 2014 6:14pm
Anderzander
The 3G ones have built in GPS - which has proved excellent in my experience.
Post #318737 24th Mar 2014 6:34pm
g-mack
yep they do, the bad elf is an option if you dont have 3g ipad. and a very good option as you will still get a signal in very remote places. so if your an overlander the bad elf is probably a better system. im gonna get one as i lose my 3g gps quite a bit in some parts of northumberland! My 109 thread
my youtube channel
Post #318739 24th Mar 2014 6:39pm
Mine is just a WiFi iPad only, so the bad elf thingy enables GPSusage then?
Does it give better Bluetooth options too? My phone has BT which is an oldish Samsung and I can't BT over photos from that which is a pain. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #318744 24th Mar 2014 6:55pm
borderterrier
Ditto
Post #318745 24th Mar 2014 6:57pm
g-mack
not sure about BT steve, but it does give you satellite locked gps. My 109 thread
my youtube channel
Post #318761 24th Mar 2014 7:32pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
The reason you need a 3G enabled iPad for built in GPS is that the radio chip has both 3G and GPS receivers in it.
You don't need to have a SIM in it to use use the GPS.
If you have a WiFi only iPad then you'll need an external GPS. If it's a Bluetooth unit, then you'll need to jailbreak the iPad to be able to connect it.
Simon
Post #318763 24th Mar 2014 7:36pm
How do you jailbreak it? (For BT) ____\We|Will|Win/___
Post #318764 24th Mar 2014 7:38pm
leeds
Previous posters are correct it does need to be a 3G one for the GPS element to work. I have used memory map on ours in loads of areas of the uk with no mobile signal and it works perfectly. I would add though that you do need to make sure you have the correct maps loaded on it before you set off because if you are relying on downloading maps as you go you can come to grief. Abroad I have found apple maps better than google maps as they cache differently.
One thing I did discover recently was a wifi ipad won't have a clue where it is even if it is connected to a 3G router.
Regards
Barbara
Post #318770 24th Mar 2014 7:52pm
Page 1 of 3 123>
