Home > Puma (Tdci) > chirping doors in 110 Puma
Defender08
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
My rear passenger off-side door chirps as we go over bumps. Things quiten when the rear passenger pulls hard on the door. Any suggestions on putting flight to this flock?
Post #317408 20th Mar 2014 4:19am
Sounds like the hinges could do with some oil and the door needs to be pulled in by adjusting the stop
Post #317412 20th Mar 2014 5:55am
Defender08
Thanks bpman - pulled in door stop, chirping quietens down for a while and then returns. Also dry lubed door striker etc, but only stopped chirping for a short while.
Post #317427 20th Mar 2014 8:54am
mk1collector
Has the plastic surround come off the door catch?
Post #317440 20th Mar 2014 10:09am
Defender08
mk1 collector the plastic is still on all door catchers albeit with grooves, but chirping and non chirping doors have same level or wear in plastic.
Post #317463 20th Mar 2014 12:10pm
Could it be that the door is chafing on the rubber seal? If so, a rubber grease may help.
Post #317473 20th Mar 2014 1:17pm
Pim
South Africa
There is a plastic retainer to hold the metal bar which goes from the door leaver on the inside to the door lock. It is connected with double sided tape to the inner door frame. When it comes loose the bar is rattling against the door frame.
Pim Series II 1960
101FC Ambulance 1977
130 1996
110 2013
90 pick up 2013
Post #317482 20th Mar 2014 2:02pm
Happyoldgit
What he says ^^^. Plus carefully remove the door card, pull back the damp seal and check the bolts that hold the inner frame along with every other screw, bolt, clip etc Wink Steve.
http://forums.lr4x4.com
Post #317517 20th Mar 2014 4:40pm
schuee
As Miserableolgit
Did this to my front passenger side door last week and cured the anoying rattle, which funnily enough sounded like it was coming from inside the middle of the dash, I found out it was the door whilst SWMBO drove for me, oh my poor gear box she still thinks she is driving her Zafira Big Cry
Post #317628 20th Mar 2014 10:13pm
Defender08
Thanks all for your best shots. Unfortunately none of the suggested causes align with the observation that the chirping stops when the rear passenger pulls on the door handle.
Post #320697 31st Mar 2014 11:40pm
Pim
South Africa
When you pull the door handle you pull it away from the metal bar I mentioned.
Pim Series II 1960
130 1996
110 2013
90 pick up 2013
Post #320731 1st Apr 2014 8:50am
Defender08
Thanks Pim- I know the clip as I've had all the door cards off for other reasons. I'll check the clip on this door in the next few days and post what I find.
Post #320764 1st Apr 2014 12:20pm
