![]() | Home > Technical > Thermostat position on a defender 200tdi |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
The correct way up is large spring at the bottom
I don't think it will fit the other way up, make sure you clean the mating faces off well and use a new gasket with some gasket blue to seal. While your have your system drained, it is well worth giving your block, radiator and heater a good blast through with lots of clean water. I usually poke a pressure washer down one hose and give it full whack to not only pressure test it but also to flow any crud out. remember to take the outlet hose off though or you will just move the crud from one part to the other! |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Yeah I have removed all the coolant hoses inc the heater hoses
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Guess how I know
Live and learn |
