Home > Technical > Thermostat position on a defender 200tdi
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
Went to replace my thermostat today aswell as do a few other jobs aswell but when I removed the top off the thermostat housing the thermostat was missing and want to know is there a specific position the thermostat should be in as my Haynes manual gives more info on the 300tdi than the 200tdi so not sure, can anyone shed any light on this please Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #316658 17th Mar 2014 5:47pm
shaggydog
The correct way up is large spring at the bottom Thumbs Up
I don't think it will fit the other way up, make sure you clean the mating faces off well and use a new gasket with some gasket blue to seal.
While your have your system drained, it is well worth giving your block, radiator and heater a good blast through with lots of clean water.
I usually poke a pressure washer down one hose and give it full whack to not only pressure test it but also to flow any crud out. remember to take the outlet hose off though or you will just move the crud from one part to the other!
Post #316680 17th Mar 2014 7:05pm
cornish rattler
Yeah I have removed all the coolant hoses inc the heater hoses Wink Graham
Post #316757 17th Mar 2014 8:39pm
shaggydog
Guess how I know Whistle
Live and learn Very Happy
Post #316759 17th Mar 2014 8:41pm
cornish rattler
Very Happy Very Happy Very Happy Graham
Post #316765 17th Mar 2014 8:45pm
