Home > Technical > Possible transmission slack and remedy
ericvv
My Puma makes a noticeable "clunk" sound when changing gears upward, certainly from 1 to 2, 2 to 3, and 3 to 4... I presume that it is some slack in the transmission, either propshaft, UJ, or even in the diff. I cannot be 100% certain, but sound seems to come from under the rear of the truck. It has always been doing this, the "clunk" is not really dramatic, but noticeable anyway.
Made an appointment at dealer for checking this out next week, any advise as to what the most likely cause would be, and what they should do to properly remedy this?
Would it be a matter of tightening things up, or if there is some slack somewhere, would it mean replacement of any of the parts at cause?
Truck is still in extended warranty period here, which I Switzerland works quite well.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #315616 13th Mar 2014 9:28am
The Puma seems to be unusually sensitive to any slack in the driveline.
Common causes of slop in the rear driveline ainclude:-
- worn outer halfshaft splines and drive flange splines. These are not lubricated and will fret, and a very small amount of wear on the spline can result in significant angular slop.
- backlash in the diff, often due to sloppy manufacture and a failure to build the thing properly. Easy enough to adjust but requires the diff to be dropped from the axle (1/2 hour job to remove, adjust and refit).
- wear or looseness in the fit of the pinion flange on the splines of the pinion shaft. May be caused either by the nut being loose, by wear in the pinion bearings causing the nut to be loose, or general wear. Can sometime be improved by Loctiting the splines, but a better bet is to renew the flange.
- wear in the propshaft UJs. Generally self-evident and easy enough to replace.
- loose roadwheel(s). Usually will also cause a heavy cyclic knock and possibly unpredictable handling. I am sure you'd have spotted this long ago!
- Worn suspension components such as A-frame bushes in the rear axle set-up
Post #315625 13th Mar 2014 10:47am
ericvv
Tks blackwolf for this extensive sum up of potential issues. Will come in handy to discuss with dealer next week when the truck goes in for checing this.
Post #315629 13th Mar 2014 11:09am
jst
most likley drive members. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #315648 13th Mar 2014 12:57pm
ericvv
Post #315665 13th Mar 2014 4:19pm
The first item on my list!
The drive member (or drive flange) is the part which fits on the splined outer end of the halfshaft and bolts to the hub to transmit drive from the halfshaft to the hub.
Post #315670 13th Mar 2014 4:38pm
MK
and a stuffed clutch would not damp most of the slacks. Puma 110" SW
Post #315671 13th Mar 2014 5:05pm
ericvv
Is what you refer to showing in the following picture and parts list? If so, which numbers in the picture and which part numbers could be the likely culprit?
http://www.landroverworkshop.com/diagrams/...0455_52627 You never actually own a Defender. You merely look after it for the next generation.
Post #315675 13th Mar 2014 5:27pm
Drive flange is item 17, same on both sides of vehicle (and on front axle)
Halfshaft item 1, obviously not the same on both sides.
That picture/page really doesn't work on a phone!
Post #315687 13th Mar 2014 6:09pm
VeeTee
Netherlands
Eric, I found some helpful info here.
There are many parts and joints involved in the drive train - gearbox, transferbox, propshaft, differential, half shafts, drive members - and every joint between to parts has a little play. All those little plays add up and it is inevitable that there always is some residual play. However, you can try to minimise each play and for the residual play you'll have to learn to handle it - it is a thing common to all 4x4 cars. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #315695 13th Mar 2014 6:38pm
jst
Sorry, my fault i missed it on your reply when i scan read.
i will butt out. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #315752 13th Mar 2014 10:02pm
No worries, I wasn't having a dig! Thumbs Up
Post #315771 13th Mar 2014 10:43pm
ericvv
Vincent, thanks for that link. Will relay it to my dealer prior to taking the truck there next week, and will specifically ask them to also check the halfshafts for wear.
As to knowing how to handle the transmission, well, if there is one person who changes gears here with respect, it is probably me. The clunk though has always been there, I guess actually from new. I only started to pay attention to it after driving the "Hunter" of kitoper here, and his transmission makes no noise at all.
The good thing is that my dealer this week recognized that there is a transmission clunk that should not be there, so we will see if they find the cause next week and remedy it.
Post #315820 14th Mar 2014 6:55am
Caterham
not wanting to open a can of worms......
I've found that while driving all can seem ok but for whatever reason when changing gear due to a lack of responsiveness to throttle imputs changing gear smoothly can seem almost impossible.......and to me give the impression of drive train slack.
no idea what the answer is etc just food for thought.
Post #315822 14th Mar 2014 7:28am
VeeTee
Netherlands
I actually though you would. Wink
Let us know what th outcome is when the truck is back from the dealer. Thumbs Up Cheers, Vincent
MySite
Post #315832 14th Mar 2014 8:08am
