Home > Maintenance & Modifications > Air box mod and decat
Page 8 of 11 <123 ... 78 91011>
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
bell-auto-services wrote:
If anyone fancys lazer cutting some wing back plates we have a drawing you could use. in the .Rar file below is 80mm and 90mm PDF and .DXF files for what we prototyped with.
https://www.defender2.net/gallery/albums/u...0mm%20.rar
Pete
Hi Pete,
Do you have a DXF file for the other piece of metal work in your post? It looks like the shape of the plastic OEM intake cover.
Thanks,
Mark http://defender90xs.blogspot.co.uk/
Post #312506 1st Mar 2014 7:44am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Hi Pete,
How are you getting on with the replacement pipe section to the airbox?
Rgds
Pete
Post #313323 4th Mar 2014 4:20am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Was playing about. Would this fit in the slot? haven't looked in there since replacing my abs modulator but fancy a shot at something like this. A 3D printer may be on the cards for this summer so i could get it printed out Smile
Also the sizing for the grill is guessed. William
Post #313711 5th Mar 2014 12:53pm
theorangebandit
I have something similar in mind to mod the fitment I already have you should have enough room foe fit that elbow
Im using a flexy hose at the minute with a 4 inch diameter
Post #313717 5th Mar 2014 1:22pm
H4mmy90
2013 Defender 90 Puma 2.2 HT Orkney Grey
There's mine out!! Noticed a difference in drivability in first and second doesn't cough and stutter like it did before, well worth the 30min to take out!!
Looking at the pipe work there is defo massive restrictions still
Post #314509 8th Mar 2014 6:04pm
Am I just dumb but why is it I can't work out how to remove the impeller thing? Do you have to cut it out of something? Or was it because I didn't take the whole air box out? I took the filter out from inside and couldn't see or feel any sign of it. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #314533 8th Mar 2014 7:43pm
H4mmy90
Custom90steve
It's an easy job. I'm not saying how I did it is the rite way and I'm sure others will advise better.
I just took the lid off the air box and removed filter not to forget unclipping wires from the lid
Undid the jublie at each end of the pipe from air box to turbo to gain access to the dirty air feed pipe
Remove the bolt that holds the dirty pipe to the inner wheel arch to give a bit of slack
Then look into the air box and you will see where it lets the air in like a bit of tube patruding in, I then slid a 1/4 extension bar up inside the air box and on the top of the tube bit you can see like two plastic nipples which I pushed in with a flat head an then with the extension bar pushed the fan thing loose
I then lifted the air box slightly and pushed down and wiggled the dirty air pipe and got the mrs to slide out the fan thing
Then put it all back together
Post #314540 8th Mar 2014 8:05pm
H4mmy90
Sorry for the crude description, would be easier to show than describe
Post #314541 8th Mar 2014 8:07pm
Cheers, I'll have a look again soon. I must admit I only had a look really.
So the access is from underneath then? _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #314546 8th Mar 2014 8:30pm
theorangebandit
For access I removed the blank on the wing top and managed to fit the pipe work. Although I attenoted to modify the abox without removing it and I damaged it. Being a brute
Post #314549 8th Mar 2014 8:41pm
Well I did the air box mod today, a lot bigger job and more work than I thought but I got there in the end. Not only did I remove the water separator but modified the box too. I'll try and get some photos up later.
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #314748 9th Mar 2014 6:58pm
Okay here's the photos:
I haven't driven yet so I don't know what the difference will be, I've modified the box carefully being careful not to damage anything other than what I wanted to remove.
I used a soldering iron to melt away what I wanted, time consuming and crude though and made sure I didn't breathe any fumes. In the last photo you can see what I finished it up as for now.
Finished rough and I need to remove a little more of the lower collar area, but I'll tidy up the edges and make it look cleaner with a file etc when I get the chance. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #314838 9th Mar 2014 9:39pm
Well I had a little test drive today and I agree with the previous comments about a bit more go in it in lower gears.
There generally seems to me to be a better throttle response especially if easing off and then you need to accelerate off again.
Less lag there.
Very Happy
Glad I did it now. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #314996 10th Mar 2014 4:20pm
landybehr
do your r/h Defenders also have the bloody thing of a air box/collector for the heating is in the way on the right inner wing too ?
If so - has anybody had a closer look at it and can assess whether it could be deformed (e.g. by means of a heat gun) to release some room between itself and the wing to let a bigger intake-air-pipe pass ?
The idea came to be because I have a snow cover - don´t know if my thought is valid - and this cover prevents ingress of much water also. So if there was a big air collector made to aid air/water seperation, this aspect could be abundant.
Post #315125 10th Mar 2014 10:30pm
munch90
at what revs does this mod have any effect on increasing the amount of air drawn in ?
Post #315132 10th Mar 2014 10:50pm
