Home > Off Topic > Grumpy Old Man Thread
Page 96 of 265 <123 ... 959697 ... 263264265>
Politicians. Evil or Very Mad ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #314692 9th Mar 2014 2:33pm
Laurie
It's looking like barbie weather and we've got a Sunday joint that can only be roasted Confused
Post #314694 9th Mar 2014 2:50pm
Haha sorry its always barbie weather here
30 sausages for the pooches and two corn fed chicks on the rotisseries Thumbs Up
Oh and cold peroni Mr. Green lots of it
Post #314726 9th Mar 2014 6:04pm
barbel jim
Barbie here too Mr. Green
Post #314732 9th Mar 2014 6:18pm
Laurie
Oi! This is a GRUMPY thread!!!!
Post #314755 9th Mar 2014 7:16pm
steve E
Wales
My grass looks s--t
Takes all year to get it looking right and then winter comes and it's start again time March each year.
Astro turf me reckons Banging Head Banging Head
Post #314758 9th Mar 2014 7:22pm
shaggydog
Chainsaws...
Bloody things are so temperamental, run fine for a hour then no matter what you do they wont start.
Swear at it call it every name under the sun, take the spark plug out, put it back in, still wont start, girlfriend comes out with cup of tea, gives it a go and starts first time.
Me thinks its time for a new one as the neighbours "MJ Tools" one worked far better than My Stihl One. That Said My Stihl one is about 30 years old now....
Post #314881 9th Mar 2014 11:00pm
Laurie
Gave up on mine. Bought an electric one and a genny.
Post #314891 9th Mar 2014 11:17pm
Romadog
Shaggydog
Old fuel ????
If you change, take a look at Makita Wink or Husqvarna Wink
I currently run a Stihl MS170 with Oregon Powersharp bar and chain.
http://www.powersharp.co.uk/page2/page12/index.html
Post #315035 10th Mar 2014 7:20pm
shaggydog
Stripped it and found the problem.
The Diaphragm which uses the exhaust to pump the chain oil had fractured and was pumping a squirt of chain oil into the cylinder on every other revolution.
Needless to say, chain oil being intentionally sticky, it is exactly not what you want in a one stroke cylinder.
Have been looking at the neighbours one on line - having used it and found it to be fantastic I'm seriously considering it.
http://www.ebay.co.uk/itm/221388316304?ssP...1423.l2649
Post #315063 10th Mar 2014 8:16pm
landy andy
Cheap chainsaws are cheap for a reason. That one won't be running in 30 months let alone 30 years. Just get the stihl repaired and serviced. It'll transform it.
(I used to repair chainsaws for a job)
Andy
Post #315073 10th Mar 2014 8:32pm
MartinK
+1 - been doing a heavy work cycle recently, taking some pretty big trees down, and cutting into pieces for the wood burner (next year after a good seasoning)....
Only problem I've had (so far after 3-4 years) is the bar (chain tensioner) bolt has come loose at the wrong end.. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #315075 10th Mar 2014 8:37pm
JWL
I have an older Husqvarna 61 with a 20" bar. It has gone through periods of heavy use and then long periods of storage, in fact I dug it out of the back of the garage a couple of months ago after nearly 10 years of storage. I replaced the fuel pickup pipe as the last one had literally melted, chucked some petrol in it, pulled the cord for a few times with the plug out to pull the petrol through and lubricate it a little. Put the plug back in and a couple of pulls later it was running again.
I remember buying it for just under £250 over 30 years ago, it certainly doesn't owe me much now. It's just a pity that I haven't worn as well.
Post #315104 10th Mar 2014 9:49pm
shaggydog
I'll make a thread for chainsaws Thumbs Up
Post #315127 10th Mar 2014 10:31pm
excossack
Spotted a Heavy-duty dual pump in the LROI Magazine and decided to look for it on the website www.paddockspares.com using the full name of the item but doesn't find it so resorted to google and searched for paddocks spares heavy duty dual pump and bingo, 1st hit.
Why can't I find by searching for it on the website arrrrgggggggggg
For those interested http://www.paddockspares.com/heavy-duty-dual-transfer-pump.html 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #315575 12th Mar 2014 9:27pm
